Album Artwork isn't matching
Postby mikext » Fri Apr 08, 2016 9:22 pm
http://imgur.com/9bdwsR1
Basically, I have done a little updating of album artwork since a lot were small. For some reason, The files themselves are fine on a lot of pictures, but the thumbnails just won't change (see above). This isn't a problem on iSub as I am able to see the correct album art.
I've tried scanning my media library, and hitting refresh above the artist list as well as hit clean up database...
Any Ideas?
edit: I guess the embedded pic won't work, please click the link.
mikext
Re: Album Artwork isn't matching
Postby frnx » Mon Apr 11, 2016 10:39 pm
The same thing has happened to me a few times, although I was never able to figure out why. :(
YMMV, but I was able to force Subsonic to refresh its thumbnail cache by re-saving the cover image, e.g. using the convert command on Linux or opening it in your image editor then choosing "Save As". Having a slightly different image file (due to re-compression or tag changes) probably did the trick.
frnx
