Unable to use Sonos Search on Remote Subsonic Library
Postby StalkS » Wed Apr 20, 2016 11:36 am
Hi All,
I have searched the forum and have seen that some users are experiencing the same issue as I am but so far I have been unable to find a solution. Basically I live away from home for a majority of the working week and travel back for the weekends - While living away I have managed to configure my Sonos Play 5 to access my home library (FLAC) using the "Remote Subsonic Library" setup shown on the Sonos section of the Subsonic main site. All works well - Except....the Search functionality from within the Sonos android App - My library is available to manually browse, queue & play but whenever I search the only results listed are from my other online services and not my Subsonic library! Is there a way to get this to function correctly as it would absolutely make my (& I guess quite a few others) year?
EDIT: I should of mentioned that the search functionality from within the Sonos android App works perfectly when I am back within my home LAN playing on the local Sonos equipment.
Problem Description: Unable to use Sonos search feature to search Remote Subsonic Library
Troubleshooting Steps: Double checked “Using a remote Subsonic server” instructions found here “http://www.subsonic.org/pages/sonos.jsp”
Playback Application and version: Sonos Play 5
Subsonic Version: 6.0.beta2 (build ef60a8) – 20 March 2016
Hardware Platform: Windows 2008 R2, 16GB RAM, AMD Turion™ II Neo N54L Dual-Core Processor 2.20 GHz
Java Memory Limit: 150MB
Problem Filename: N/A - All files are FLAC?
Last ten log file lines:
[20/04/16 11:59:28 BST]   INFO   AudioScrobblerService   Successfully registered submission for song 'Wish You Were Here' for user stalks_uk at Last.fm: Wed Apr 20 11:58:59 BST 2016
[20/04/16 11:59:42 BST]   DEBUG   StreamController   GET /rest/stream.view?u=admin&v=1.14.0&c=PolySonic&f=json&s=4ymqOLfEBGVJ5tcA&t=965fbaecb6a37a424310c4d3bbe35ce4&maxBitRate=320&id=13225, Range: bytes=7372800-8388607
[20/04/16 11:59:42 BST]   DEBUG   StreamController   Content-Length: 1015808
[20/04/16 11:59:42 BST]   DEBUG   StreamController   Content-Range: 7372800-8388607/13600000
[20/04/16 11:59:42 BST]   INFO   TranscodeInputStream   Starting transcoder: c:\subsonic\transcode\ffmpeg -i E:\ServerFolders\Music\NEWFLAC\Pink Floyd\Wish You Were Here\04 Wish You Were Here.flac -map 0:0 -b:a 320k -v 0 -f mp3 -
[20/04/16 11:59:53 BST]   DEBUG   StreamController   GET /rest/stream.view?u=admin&v=1.14.0&c=PolySonic&f=json&s=4ymqOLfEBGVJ5tcA&t=965fbaecb6a37a424310c4d3bbe35ce4&maxBitRate=320&id=13225, Range: bytes=7372800-13599999
[20/04/16 11:59:53 BST]   DEBUG   StreamController   Content-Length: 6227200
[20/04/16 11:59:53 BST]   DEBUG   StreamController   Content-Range: 7372800-13599999/13600000
[20/04/16 11:59:53 BST]   INFO   TranscodeInputStream   Starting transcoder: c:\subsonic\transcode\ffmpeg -i E:\ServerFolders\Music\NEWFLAC\Pink Floyd\Wish You Were Here\04 Wish You Were Here.flac -map 0:0 -b:a 320k -v 0 -f mp3 -
[20/04/16 11:59:53 BST]   WARN   RESTFilter   Error in REST API: EofException
[20/04/16 11:59:53 BST]   ERROR   JAXBWriter   Failed to marshal JAXB
[20/04/16 11:59:53 BST]   ERROR   RESTFilter   Failed to write error response.
All the best
StalkS
StalkS
Re: Unable to use Sonos Search on Remote Subsonic Library
Postby StalkS » Thu May 05, 2016 10:11 am
*BUMP!
StalkS
Postby StalkS » Thu Oct 13, 2016 9:26 am
Bump!
StalkS
Postby StalkS » Wed Jun 13, 2018 1:17 pm
2 Year Bump
StalkS
Users browsing this forum: No registered users and 133 guests
