Database error
Database error
Postby jl55378008 » Thu Apr 21, 2016 3:06 pm
I had the same 503 error as others have reported here. Reverted to the stable version of Subsonic (from the 6.x beta), and restored my database from the backup. Ever since then it's working mostly correctly, but I've found a few artists/folders in my library that give errors when I try to view them. Also, the "random albums" feature on the homepage doesn't show anything.
This is the error that I get:
Exception   org.springframework.dao.TransientDataAccessResourceException
Message   PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
Java version   Oracle Corporation 1.7.0_71
Operating system   Windows 7 6.1
Server   jetty-6.1.x
Memory   Used 97 of 145 MB
Stack trace   org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
   at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:81)
   at net.sourceforge.subsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:165)
   at net.sourceforge.subsonic.service.MediaFileService.checkLastModified(MediaFileService.java:129)
   at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:198)
   at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:174)
   at net.sourceforge.subsonic.controller.MainController.handleRequestInternal(MainController.java:92)
   at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:59)
Caused by: java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
   ... 62 more
jl55378008
