Troubleshoot Last.fm scrobbling from Dsub
Postby Mauriac » Thu Apr 21, 2016 5:05 pm
Recently installed to the latest beta for windows and set up Dsub on my Android for music streaming and last.fm scrobbling.
After a few strange mishaps the Android app seems to be working properly now (as far as playback goes) but scrobbling is not working properly in any way.
While playing from my phone, most of the times my last fm profile page does not register anything, and other times it scrobbles the last played song on the web interface 3 times in one minute.
Any idea on what may be causing this? Anything I should check for?
Here are some logs:
[4/21/16 2:55:34 PM EEST]   DEBUG   AbstractDao   63839 ms: select id, media_file_id, audio_track_id, username, status, target_file, log_file, bit_rate, progress_seconds, created, changed, started from video_conversion where status=? order by created
[4/21/16 2:57:07 PM EEST]   DEBUG   AbstractDao   90129 ms: select id, media_file_id, audio_track_id, username, status, target_file, log_file, bit_rate, progress_seconds, created, changed, started from video_conversion where status=? order by created
[4/21/16 2:59:10 PM EEST]   DEBUG   AbstractDao   100946 ms: select id, media_file_id, audio_track_id, username, status, target_file, log_file, bit_rate, progress_seconds, created, changed, started from video_conversion where status=? order by created
[4/21/16 3:01:23 PM EEST]   DEBUG   AbstractDao   4676 ms: select id, media_file_id, audio_track_id, username, status, target_file, log_file, bit_rate, progress_seconds, created, changed, started from video_conversion where status=? order by created
[4/21/16 3:01:30 PM EEST]   DEBUG   AbstractDao   3652 ms: select id, media_file_id, audio_track_id, username, status, target_file, log_file, bit_rate, progress_seconds, created, changed, started from video_conversion where status=? order by created
[4/21/16 3:02:48 PM EEST]   DEBUG   AbstractDao   75535 ms: select id, media_file_id, audio_track_id, username, status, target_file, log_file, bit_rate, progress_seconds, created, changed, started from video_conversion where status=? order by created
[4/21/16 3:04:34 PM EEST]   DEBUG   AbstractDao   102204 ms: select id, media_file_id, audio_track_id, username, status, target_file, log_file, bit_rate, progress_seconds, created, changed, started from video_conversion where status=? order by created
[4/21/16 3:05:26 PM EEST]   DEBUG   AbstractDao   45833 ms: select id, media_file_id, audio_track_id, username, status, target_file, log_file, bit_rate, progress_seconds, created, changed, started from video_conversion where status=? order by created
[4/21/16 3:54:41 PM EEST]   INFO   NetworkService   Successfully forwarding port 4040.
[4/21/16 4:54:41 PM EEST]   INFO   NetworkService   Successfully forwarding port 4040.
[4/21/16 5:54:41 PM EEST]   INFO   NetworkService   Successfully forwarding port 4040.
[4/21/16 6:54:41 PM EEST]   INFO   NetworkService   Successfully forwarding port 4040.
[4/21/16 7:35:17 PM EEST]   DEBUG   StreamController   POST /rest/stream.view?u=admin&p=enc:62756c6c6574&v=1.2.0&c=DSub&id=33454&maxBitRate=320, Range: null
[4/21/16 7:35:17 PM EEST]   INFO   TranscodeInputStream   Starting transcoder: c:\subsonic\transcode\ffmpeg -i D:\Music\Queens of the Stone Age\2005 - Lullabies to Paralyze\07 - Little Sister.flac -map 0:0 -b:a 320k -v 0 -f mp3 -
[4/21/16 7:35:20 PM EEST]   WARN   RESTFilter   Error in REST API: NullPointerException
[4/21/16 7:42:00 PM EEST]   WARN   RESTFilter   Error in REST API: NullPointerException
[4/21/16 7:44:42 PM EEST]   WARN   RESTFilter   Error in REST API: NullPointerException
[4/21/16 7:45:23 PM EEST]   DEBUG   StreamController   GET /stream?player=3&id=24469&auth=1990625416, Range: bytes=0-1048575
[4/21/16 7:45:24 PM EEST]   DEBUG   StreamController   Content-Length: 1048576
[4/21/16 7:45:24 PM EEST]   DEBUG   StreamController   Content-Range: 0-1048575/6200000
[4/21/16 7:45:24 PM EEST]   INFO   TranscodeInputStream   Starting transcoder: c:\subsonic\transcode\ffmpeg -i D:\Music\Martin O'Donnell & Michael Salvatori\1997 - Myth - The Fallen Lords\01 - Prologue.flac -map 0:0 -b:a 320k -v 0 -f mp3 -
[4/21/16 7:45:24 PM EEST]   DEBUG   StreamController   GET /stream?player=3&id=24469&auth=1990625416, Range: bytes=0-6199999
[4/21/16 7:45:24 PM EEST]   DEBUG   StreamController   Content-Length: 6200000
[4/21/16 7:45:24 PM EEST]   DEBUG   StreamController   Content-Range: 0-6199999/6200000
[4/21/16 7:45:25 PM EEST]   INFO   AudioScrobblerService   Successfully registered now playing for song 'Prologue' for user Maeldun at Last.fm: Thu Apr 21 19:45:24 EEST 2016
[4/21/16 7:45:26 PM EEST]   INFO   AudioScrobblerService   Successfully registered submission for song 'Prologue' for user Maeldun at Last.fm: Thu Apr 21 19:45:24 EEST 2016
[4/21/16 7:45:27 PM EEST]   INFO   AudioScrobblerService   Successfully registered now playing for song 'Prologue' for user Maeldun at Last.fm: Thu Apr 21 19:45:24 EEST 2016
[4/21/16 7:46:43 PM EEST]   INFO   AudioScrobblerService   Successfully registered submission for song 'Prologue' for user Maeldun at Last.fm: Thu Apr 21 19:46:42 EEST 2016
[4/21/16 7:49:27 PM EEST]   DEBUG   StreamController   GET /stream?player=3&id=24469&auth=1990625416, Range: null
[4/21/16 7:49:27 PM EEST]   INFO   TranscodeInputStream   Starting transcoder: c:\subsonic\transcode\ffmpeg -i D:\Music\Martin O'Donnell & Michael Salvatori\1997 - Myth - The Fallen Lords\01 - Prologue.flac -map 0:0 -b:a 320k -v 0 -f mp3 -
[4/21/16 7:49:27 PM EEST]   DEBUG   StreamController   GET /stream?player=3&id=24469&auth=1990625416, Range: bytes=0-
[4/21/16 7:49:27 PM EEST]   DEBUG   StreamController   Content-Length: 6200000
[4/21/16 7:49:27 PM EEST]   DEBUG   StreamController   Content-Range: 0-6199999/6200000
[4/21/16 7:49:28 PM EEST]   INFO   AudioScrobblerService   Successfully registered now playing for song 'Prologue' for user Maeldun at Last.fm: Thu Apr 21 19:49:27 EEST 2016
[4/21/16 7:49:30 PM EEST]   WARN   CoverArtController   Failed to process cover art D:\Music\Rolling Stones\1965 - Out of our Heads (US)\Back_Cover.jpg: java.lang.OutOfMemoryError: Java heap space
[4/21/16 7:49:30 PM EEST]   INFO   AudioScrobblerService   Successfully registered submission for song 'Prologue' for user Maeldun at Last.fm: Thu Apr 21 19:49:27 EEST 2016
[4/21/16 7:49:31 PM EEST]   INFO   AudioScrobblerService   Successfully registered now playing for song 'Prologue' for user Maeldun at Last.fm: Thu Apr 21 19:49:27 EEST 2016
[4/21/16 7:49:35 PM EEST]   INFO   AudioScrobblerService   Successfully registered submission for song 'Prologue' for user Maeldun at Last.fm: Thu Apr 21 19:49:34 EEST 2016
[4/21/16 7:50:38 PM EEST]   DEBUG   StreamController   GET /stream?player=3&id=24469&auth=1990625416, Range: null
[4/21/16 7:50:38 PM EEST]   INFO   TranscodeInputStream   Starting transcoder: c:\subsonic\transcode\ffmpeg -i D:\Music\Martin O'Donnell & Michael Salvatori\1997 - Myth - The Fallen Lords\01 - Prologue.flac -map 0:0 -b:a 320k -v 0 -f mp3 -
[4/21/16 7:50:39 PM EEST]   INFO   AudioScrobblerService   Successfully registered now playing for song 'Prologue' for user Maeldun at Last.fm: Thu Apr 21 19:50:38 EEST 2016
[4/21/16 7:50:45 PM EEST]   INFO   AudioScrobblerService   Successfully registered submission for song 'Prologue' for user Maeldun at Last.fm: Thu Apr 21 19:50:44 EEST 2016
[4/21/16 7:54:41 PM EEST]   INFO   NetworkService   Successfully forwarding port 4040.
[4/21/16 7:58:27 PM EEST]   DEBUG   StreamController   GET /stream?player=3&id=24469&auth=1990625416, Range: bytes=0-
[4/21/16 7:58:27 PM EEST]   DEBUG   StreamController   Content-Length: 6200000
[4/21/16 7:58:27 PM EEST]   DEBUG   StreamController   Content-Range: 0-6199999/6200000
[4/21/16 7:58:27 PM EEST]   INFO   TranscodeInputStream   Starting transcoder: c:\subsonic\transcode\ffmpeg -i D:\Music\Martin O'Donnell & Michael Salvatori\1997 - Myth - The Fallen Lords\01 - Prologue.flac -map 0:0 -b:a 320k -v 0 -f mp3 -
[4/21/16 7:58:28 PM EEST]   INFO   AudioScrobblerService   Successfully registered now playing for song 'Prologue' for user Maeldun at Last.fm: Thu Apr 21 19:58:27 EEST 2016
Mauriac
