Anything happened to subsonic.org ?
Postby utopian » Mon Apr 25, 2016 1:36 pm
My easy to remember subsonic.org name now shows as..." connect to subsonic.org:80 timed out" .. port forwarding has been in place for years
utopian
Re: Anything happened to subsonic.org ?
Postby kilgoretrout64 » Mon Apr 25, 2016 1:47 pm
I can't connect to my subsonic server. I think subsonic.org is down
kilgoretrout64
Postby ibriscoe » Mon Apr 25, 2016 1:49 pm
Looks like the server is totally down.
The home page won't load, and neither will the download page - which is frustrating, as I need to download the latest war file.
nslookup on http://www.subsonic.org gives 198.71.81.108, which I can't even ping successfully.
Anyone have contact details for the site admin?
ibriscoe
Postby burn913 » Mon Apr 25, 2016 3:25 pm
I'm down too...
burn913
Postby rwgraft » Mon Apr 25, 2016 3:35 pm
Same here. Sindre...help!
rwgraft
Postby fracturetrey » Mon Apr 25, 2016 3:39 pm
Yep, also seeing the same.
Keep in mind, until this is resolved, you can still access your server at your own IP address and/or dynamic DNS name. For instance, http://w.x.y.z:7080/subsonic
fracturetrey
Postby coacharnold » Mon Apr 25, 2016 9:30 pm
I'm unable as well ...... looks like subsonic is down. Whats weird is I can hit the test server; they must have that on a completely different network.
Glad I'm not the only one
T
coacharnold
Postby sviatapolk » Mon Apr 25, 2016 10:19 pm
You can still reach it with your home IP address :forwarded port.
This is only the second time this has happened in the 4 years I've been using Subsonic
sviatapolk
Postby nickmv » Mon Apr 25, 2016 10:28 pm
sviatapolk wrote:You can still reach it with your home IP address :forwarded port.
Been using it for 5-6 years, and this is probably the 10th time it's happened that I've witnessed. Not that it's frequent, but it's certainly not as rare as your experience.
nickmv
Postby Mike Marrone » Mon Apr 25, 2016 11:42 pm
Same here... it's happened before. Hopefully the server will be back up soon.
Mike Marrone
Mike Marrone
Postby otis_bartleh » Tue Apr 26, 2016 12:36 am
Yup noticed it to, saw the other thread first, oops..
otis_bartleh
Postby fatreg » Tue Apr 26, 2016 6:37 am
Thanks! Saved me behind, can now listen to music at work again unlike from about 3pm yesterday.
fatreg
Postby johnnycroy » Tue Apr 26, 2016 9:52 am
Checking in to see if the following errors are related to the login issues. Up until yesterday I got the following errors in my log related to router issues.
[2016-04-25 23:36:55,497] INFO HsqlDaoHelper - Checking database schema.
[2016-04-25 23:37:08,391] INFO HsqlDaoHelper - Done checking database schema.
[2016-04-25 23:37:09,218] INFO SettingsService - Java: 1.8.0_91, OS: Linux
[2016-04-25 23:37:09,374] INFO VersionService - Resolved local Subsonic version to: 6.0.beta2
[2016-04-25 23:37:10,785] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Tue Apr 26 00:00:00 EDT 2016
[2016-04-25 23:37:11,100] INFO UPnPService - Starting UPnP service...
[2016-04-25 23:37:11,397] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Mon Apr 25 23:42:11 EDT 2016
[2016-04-25 23:37:11,710] INFO UPnPService - Disabling UPnP/DLNA media server
[2016-04-25 23:37:11,713] INFO UPnPService - Starting UPnP service - Done!
[2016-04-25 23:37:21,212] WARN NetworkService - Failed to create port forwarding.
java.lang.Exception: null: Error: Current state of service prevents invoking that action. Connection error or no response received.
at net.sourceforge.subsonic.service.upnp.ClingRouter.addPortMappingImpl(ClingRouter.java:116)
at net.sourceforge.subsonic.service.upnp.ClingRouter.addPortMapping(ClingRouter.java:89)
at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.execute(NetworkService.java:151)
at net.sourceforge.subsonic.service.NetworkService$Task.run(NetworkService.java:318)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
To my untrained eye, that java error that was thrown appears to indicate so, but wanted to ask more knowledgeable folks on this site. Reinstalled both subsonic and java on my raspberry pi with no success. Router was checked and all settings were fine with regards to port forwarding, so that is not the issue.
Best,
J
johnnycroy
Postby centuryx476 » Tue Apr 26, 2016 11:19 am
YAY everything is back up and running.
What happened Sindre?
centuryx476
Postby utopian » Tue Apr 26, 2016 1:15 pm
yep i'm back..Many Thanks :D :D
utopian
