Runnung Subsonic on Ubuntu 16.04
Postby FoxBJK » Tue Apr 26, 2016 11:09 am
Ubuntu 16.04 recently came out, but it does not include support for OpenJDK-7. Has anyone gotten Subsonic to work using OpenJDK 8 or 9? If so, how? I can't Subsonic to start on this OS.
FoxBJK
Re: Runnung Subsonic on Ubuntu 16.04
Postby deckardk » Tue Apr 26, 2016 10:09 pm
Same issue here, the subsonic service seems to be running but I can't access it through my browser. I tried installing openjdk-7 using this:
sudo add-apt-repository ppa:openjdk-r/ppa
sudo apt-get update
sudo apt-get install openjdk-7-jre
but still nothing at all.
deckardk
Postby FoxBJK » Wed Apr 27, 2016 11:36 am
UPDATE - Subsonic is running on my machine, but the web interface still doesn't work. I didn't do anything to get it running, I just noticed the Android app I use (DSub) has been syncing new podcasts.
When searching for installed packages, specifically versions of openjdk, here's what I get:
foxbjk@Zoidberg:~$ dpkg --get-selections | grep openjdk
openjdk-7-jre-headless:amd64                    deinstall
openjdk-8-jre:amd64                             install
openjdk-8-jre-headless:amd64                    install
openjdk-9-jre:amd64                             install
openjdk-9-jre-headless:amd64                    install
FoxBJK
Postby deckardk » Thu Apr 28, 2016 9:04 pm
Exactly the same for me now, Dsub works and the web interface doesn't. Hoping for a fix soon :(
deckardk
Postby dreamwraith » Fri Apr 29, 2016 7:39 am
Got it running here. I just had to install openjdk-8 instead of 7, and then start it up.
dreamwraith
Postby FoxBJK » Fri Apr 29, 2016 11:55 am
dreamwraith wrote:Got it running here. I just had to install openjdk-8 instead of 7, and then start it up.
Please give more details about your setup if you can. I have openjdk-8 installed already, but Subsonic still doesn't work. What's worse is that I can't even get it to restart. Command line, nor the logs, show a single error.
FoxBJK
Postby insann » Fri Apr 29, 2016 2:23 pm
maybe ubuntu still think that you're default version is version 7 and not 8 !
first see wich version you have :
sudo update-alternatives --display java
then try to change the default version :
sudo update-alternatives --config java
Insann
With no logs, how do you find problems ?
insann
Postby deckardk » Fri Apr 29, 2016 8:57 pm
Insann
Nice, thanks. This is what I did for my setup:
sudo apt install openjdk-8-jdk
sudo update-alternatives --config java  # choose jdk-8 here
sudo service subsonic stop
sudo service subsonic start
And bam! The web interface was back up. Thanks everyone.
deckardk
Postby FoxBJK » Sun May 01, 2016 6:09 pm
I was finally able to get it working also. Did some digging and found in subsonic_sh.log that the error was "java: not found". I had 9, and the system was trying to use that, but Subsonic's web UI still didn't work. Only fix was to remove all versions except for the 8-jdk, and now everything's running fine. 6.0 went live yesterday and I got it installed just a moment ago.
Thanks for the help all!
FoxBJK
