Status: No router found
Postby dgreenhbs99 » Wed Apr 27, 2016 12:06 am
Hi.
I can't get the "Automatically configure your router to allow incoming connections to Subsonic (using UPnP or NAT-PMP port forwarding)" to read anything but "Status: No router found".
I have a Netgear Nighthawk X6 R8000, with ports 4040 and, for good measure, 80, forwarded with TCP. I also have UPnP enabled on the router.
Web access is fine, as is the router's control panel...I see nothing amiss except Subsonic's error message.
Any idea what might be going on?
Also, though I pointed Subsonic to my media files, they don't show up in the web interface at all.
Puzzled.
dan
dgreenhbs99
Re: Status: No router found
Postby alphawave7 » Wed Apr 27, 2016 3:15 am
If you have manually forwarded your port, UNCHECK 'automatically..., and ensure admin has media privilges in Settings-Users.
Postby dgreenhbs99 » Wed Apr 27, 2016 4:11 am
That did the trick. Thanks!
dgreenhbs99
