SubSonic jukebox output broken in Debian 8 (Ubuntu as well?)
Postby benito » Sat Apr 30, 2016 2:41 am
KEYWORDS: Sunsonic Linux Debian Ubuntu no jukebox sound output jukebox: javax.sound.sampled.LineUnavailableException
I installed SubSonic, following the instructions on the subsonic website.
First, install Java: sudo apt-get install openjdk-7-jre
Download the Subsonic .deb package and install it: sudo dpkg -i subsonic-x.x.deb
All went to plan, and even Android playback does work, but Jukebox output errors out and there is no sound output.
Some background:
I had Subsonic working well with jukebox output under Debian 7 (using Sun java package).
Initially I tried Subsonic version 5.3.beta2 (the same version that worked on Debian7) ; no jukebox output, so I upgraded to latest 6.0.beta2, still no output.
I have a suspicion that Java version is to blame, but cannot prove it, nor know what to try next. ( I did as I was told to install)
P.S. Sun Java is no longer available for install on Debian / Ubuntu.
Here are the technical details:
Problem Description: No jukebox sound output
Troubleshooting Steps: Test sound output with alsaplayer=OK speakertest=OK
Playback Application and version: SubSonic Jukebox output to server PC Line-out.
Subsonic Version: 6.0.beta2 (build d85b52) – March 23, 2016
Server Version: jetty-6.1.x, java 1.7.0_95, Linux (105.1 MB / 134.0 MB
Hardware Platform: Linux (8.4 jesse) 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt25-2 (2016-04-08) x86_64 GNU/Linux
Java Memory Limit: (Windows: found in the Subsonic Agent in the taskbar)
Problem Filename: all jukebox output fails
Output from ffmpeg -i: (If you open a command prompt and type 'ffmpeg -i <filename>' what is the output? Ideally put this in a "code" block)
Last ten log file lines: INFO TranscodeInputStream - Starting transcoder: /var/subsonic/transcode/ffmpeg -ss 0 -i /home/music/i/INXS/INXS -Shabooh Shoobah - 1982/03 - Spy of Love.mp3 -map 0:0 -v 0 -ar 44100 -ac 2 -f s16be -
[2016-04-30 11:28:03,263] ERROR JukeboxService - Error in jukebox: javax.sound.sampled.LineUnavailableException
        at org.classpath.icedtea.pulseaudio.PulseAudioMixer.openImpl(PulseAudioMixer.java:714)
        at org.classpath.icedtea.pulseaudio.PulseAudioMixer.openLocal(PulseAudioMixer.java:588)
        at org.classpath.icedtea.pulseaudio.PulseAudioMixer.openLocal(PulseAudioMixer.java:584)
        at org.classpath.icedtea.pulseaudio.PulseAudioMixer.open(PulseAudioMixer.java:579)
        at org.classpath.icedtea.pulseaudio.PulseAudioDataLine.open(PulseAudioDataLine.java:94)
        at org.classpath.icedtea.pulseaudio.PulseAudioSourceDataLine.open(PulseAudioSourceDataLine.java:75)
#tail /var/log/subsonic/subsonic.log
#java -version
java version "1.7.0_95"
OpenJDK Runtime Environment (IcedTea 2.6.4) (7u95-2.6.4-1~deb8u1)
OpenJDK 64-Bit Server VM (build 24.95-b01, mixed mode)
# /var/subsonic/transcode/ffmpeg -i /etc/startup.wav
ffmpeg version 3.0-static http://johnvansickle.com/ffmpeg/  Copyright (c) 2000-2016 the FFmpeg developers
  built with gcc 5.3.1 (Debian 5.3.1-8) 20160205
  configuration: --enable-gpl --enable-version3 --disable-shared --disable-debug --enable-runtime-cpudetect --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfribidi --disable-indev=sndio --disable-outdev=sndio --enable-librtmp --enable-libmfx --cc=gcc
  libavutil      55. 17.103 / 55. 17.103
  libavcodec     57. 24.102 / 57. 24.102
  libavformat    57. 25.100 / 57. 25.100
  libavdevice    57.  0.101 / 57.  0.101
  libavfilter     6. 31.100 /  6. 31.100
  libswscale      4.  0.100 /  4.  0.100
  libswresample   2.  0.101 /  2.  0.101
  libpostproc    54.  0.100 / 54.  0.100
Guessed Channel Layout for  Input Stream #0.0 : mono
Input #0, wav, from '/etc/startup.wav':
  Metadata:
    artist          : Brian Eno
    copyright       : 1995 Microsoft Corporation
    title           : The Microsoft Sound
    album           : Microsoft Windows 95
    ISRC            : Microsoft Corporation
                    : One Microsoft Way
                    : Redmond, WA  98052-6399
  Duration: 00:00:06.12, bitrate: 177 kb/s
    Stream #0:0: Audio: pcm_u8 ([1][0][0][0] / 0x0001), 22050 Hz, 1 channels, u8, 176 kb/s
#dpkg -l |grep (what I think is relevant)
ii  subsonic                           6.0.beta2                         all          A web-based music streamer, jukebox and Podcast receiver
ii  openjdk-7-jre:amd64    7u95-2.6.4-1~deb amd64            OpenJDK Java runtime, using Hotspot JIT
ii  openjdk-7-jre-headless 7u95-2.6.4-1~deb amd64            OpenJDK Java runtime, using Hotspot JIT (headless)
ii  libasound2:amd64                   1.0.28-1                          amd64        shared library for ALSA applications
ii  libasound2-data                    1.0.28-1                          all          Configuration files and profiles for ALSA drivers
ii  libasound2-plugins:amd64           1.0.28-1+b1                       amd64        ALSA library additional plugins
ii  libcanberra0:amd64                 0.30-2.1                          amd64        simple abstract interface for playing event sounds
ii  libmikmod3:amd64                   3.3.7-1                           amd64        Portable sound library
ii  libtext-soundex-perl               3.4-1+b2                          amd64        implementation of the soundex algorithm
ii  pulseaudio                         5.0-13                            amd64        PulseAudio sound server
ii  pulseaudio-module-x11              5.0-13                            amd64        X11 module for PulseAudio sound server
ii  pulseaudio-utils                   5.0-13                            amd64        Command line tools for the PulseAudio sound server
ii  alsa-base                          1.0.27+1                          all          dummy package to ease purging of obsolete conffiles
ii  alsa-utils                         1.0.28-1                          amd64        Utilities for configuring and using ALSA
ii  alsaplayer-alsa                    0.99.81-1+b1                      amd64        alsaplayer output module for ALSA
ii  alsaplayer-common                  0.99.81-1+b1                      amd64        audio player (common files)
ii  alsaplayer-gtk                     0.99.81-1+b1                      amd64        alsaplayer gtk interface
ii  alsaplayer-text                    0.99.81-1+b1                      amd64        alsaplayer text interface
benito
[Solved] SubSonic jukebox output broken in Debian 8
Postby benito » Sun May 01, 2016 6:32 am
I found the solution myself, with a little experimentation.
It seems that the Java implementation was the issue.
OpenJDK cannot produce sound output under Debian (and Ubuntu as well I suspect).
(True at least of OpenJDK 2.6.4 circa May 2016)
I replaced OpenJDK with Oracle Java and sound output is good.
Oracle Java (Formerly Sun Java) is no longer a package included with Debian or Ubuntu, but there are sources for .DEB packages, so install is pretty easy.
First, remove OpenJDK, so as not to clash with Oracle Java.
sudo apt-get purge openjdk-7-jre
sudo apt-get autoremove
Then install Oracle Java (v1.8.0_91-b14 at time of writing)
su -
echo "deb http://ppa.launchpad.net/webupd8team/java/ubuntu xenial main" | tee /etc/apt/sources.list.d/webupd8team-java.list
echo "deb-src http://ppa.launchpad.net/webupd8team/java/ubuntu xenial main" | tee -a /etc/apt/sources.list.d/webupd8team-java.list
apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys EEA14886
apt-get update
apt-get install oracle-java8-installer
et Voila! ce finis.
Sindre, perhaps you may wish to update the instructions for Debian/Ubuntu install with a caveat for those who use Jukebox mode.
I hope this post helps other save time and frustration.
Regards,
Benitio.
benito
Users browsing this forum: No registered users and 58 guests
