[solved] v6.0 gives "Failed to find parameter: instanceId"
Postby MikeLegit » Sat Apr 30, 2016 10:44 pm
I replaced my WAR file with the latest v6.0 file and now the web interface doesn't work. Also cannot connect to the server from my phone however the web interface starts to come up partially, but then errors out with
"Failed to find parameter: instanceId (check server log for more into)"
Any ideas how to fix this?
cat home/subsonic.log
[/share/MD0_DATA/.qpkg/Subsonic] # cat home/subsonic.log
[2016-04-30 22:20:33,250] INFO HsqlDaoHelper - Checking database schema.
[2016-04-30 22:20:38,825] INFO Schema60 - Updating database schema to version 26.
[2016-04-30 22:20:38,827] INFO Schema60 - Deleting obsolete video transcodings.
[2016-04-30 22:20:39,096] INFO Schema60 - Database table 'video_conversion' not found.  Creating it.
[2016-04-30 22:20:39,101] INFO Schema60 - Database table 'video_conversion' was created successfully.
[2016-04-30 22:20:39,109] INFO Schema60 - Role 'video_conversion' not found in database. Creating it.
[2016-04-30 22:20:39,117] INFO Schema60 - Role 'video_conversion' was created successfully.
[2016-04-30 22:20:39,119] INFO Schema60 - Database column 'user_settings.show_index_in_side_bar' not found.  Creating it.
[2016-04-30 22:20:39,123] INFO Schema60 - Database column 'user_settings.show_index_in_side_bar' was added successfully.
[2016-04-30 22:20:39,123] INFO HsqlDaoHelper - Done checking database schema.
[2016-04-30 22:20:39,844] INFO SettingsService - Java: 1.8.0_65, OS: Linux
[2016-04-30 22:20:39,964] INFO VersionService - Resolved local Subsonic version to: 6.0
[2016-04-30 22:20:40,949] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Sun May 01 03:00:00 GMT 2016
[2016-04-30 22:20:41,219] INFO UPnPService - Starting UPnP service...
[2016-04-30 22:20:41,991] INFO UPnPService - Disabling UPnP/DLNA media server
[2016-04-30 22:20:41,993] INFO UPnPService - Starting UPnP service - Done!
[2016-04-30 22:20:47,181] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Sat Apr 30 22:25:47 GMT 2016
[2016-04-30 22:20:51,263] WARN NetworkService - No UPnP router found.
[2016-04-30 22:21:01,901] INFO BootstrapVerificationFilter - Servlet container: jetty-6.1.x
[2016-04-30 22:21:08,782] INFO VersionService - Resolved latest Subsonic final version to: 6.0
[2016-04-30 22:21:08,783] INFO VersionService - Resolved latest Subsonic beta version to: 6.0.beta2
[2016-04-30 22:25:47,181] INFO PodcastService - Starting scheduled Podcast refresh.
[2016-04-30 22:25:47,228] INFO PodcastService - Completed scheduled Podcast refresh.
A server restart looks ok...
[2016-04-30 22:32:16,362] INFO HsqlDaoHelper - Checking database schema.
[2016-04-30 22:32:21,933] INFO HsqlDaoHelper - Done checking database schema.
[2016-04-30 22:32:22,451] INFO SettingsService - Java: 1.8.0_65, OS: Linux
[2016-04-30 22:32:22,553] INFO VersionService - Resolved local Subsonic version to: 6.0
[2016-04-30 22:32:23,982] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Sun May 01 03:00:00 GMT 2016
[2016-04-30 22:32:24,237] INFO UPnPService - Starting UPnP service...
[2016-04-30 22:32:24,615] INFO UPnPService - Disabling UPnP/DLNA media server
[2016-04-30 22:32:24,617] INFO UPnPService - Starting UPnP service - Done!
[2016-04-30 22:32:27,805] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Sat Apr 30 22:37:27 GMT 2016
[2016-04-30 22:32:34,273] WARN NetworkService - No UPnP router found.
[2016-04-30 22:32:43,296] INFO BootstrapVerificationFilter - Servlet container: jetty-6.1.x
cat subsonic_sh.log
92 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@1973e9b: display name [org.springframework.context.support.ClassPathXmlApplicationContext@1973e9b]; startup date [Sat Apr 30 22:32:09 GMT 2016]; root of context hierarchy
269 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
1406 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@1973e9b]: org.springframework.beans.factory.support.DefaultListableBeanFactory@a7e666
1461 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@a7e666: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
1550 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: /share/MD0_DATA/.qpkg/Subsonic/subsonic.war
Extracting webapp to /share/MD0_DATA/.qpkg/Subsonic/home/jetty/a7857c
1702 [main] INFO org.mortbay.log - jetty-6.1.x
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/share/MD0_DATA/.qpkg/Subsonic/subsonic-booter-jar-with-dependencies.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/share/MD0_DATA/.qpkg/Subsonic/home/jetty/a7857c/webapp/WEB-INF/lib/slf4j-log4j12-1.6.1.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
4157 [main] INFO /subsonic - Initializing Spring root WebApplicationContext
4158 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
4255 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@123d65: display name [Root WebApplicationContext]; startup date [Sat Apr 30 22:32:13 GMT 2016]; root of context hierarchy
4415 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
4756 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
4929 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-cache.xml]
5034 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-sonos.xml]
5201 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [META-INF/cxf/cxf.xml]
5306 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [META-INF/cxf/cxf-servlet.xml]
6448 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@123d65]: org.springframework.beans.factory.support.DefaultListableBeanFactory@151e434
7142 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@151e434: defining beans [playerDao,mediaFileDao,artistDao,albumDao,playlistDao,playQueueDao,internetRadioDao,musicFileInfoDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,shareDao,bookmarkDao,videoConversionDao,daoHelper,mediaFileService,securityService,settingsService,mediaScannerService,searchService,networkService,playerService,playlistService,versionService,statusService,ratingService,musicIndexService,audioScrobblerService,transcodingService,shareService,podcastService,adService,jukeboxService,folderBasedContentDirectory,upnpService,lastFmService,videoConversionService,sonosService,metaDataParserFactory,ajaxMultiService,ajaxNowPlayingService,ajaxPlayQueueService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxStarService,ajaxTagService,ajaxTransferService,ajaxChatService,localeResolver,loginFailureLogger,net.sourceforge.subsonic.security.SubsonicApplicationEventListener#0,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheFactory,userCache,mediaFileMemoryCache,cxf,org.apache.cxf.bus.spring.BusWiringBeanFactoryPostProcessor,org.apache.cxf.bus.spring.Jsr250BeanPostProcessor,org.apache.cxf.bus.spring.BusExtensionPostProcessor,sonosEndpoint,sonosHelper]; root of factory hierarchy
7216 [main] INFO org.springframework.jdbc.datasource.DriverManagerDataSource - Loaded JDBC driver: org.hsqldb.jdbcDriver
23919 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
23951 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public net.sourceforge.subsonic.ajax.UploadInfo net.sourceforge.subsonic.ajax.TransferService.getUploadInfo()] with attributes [[ROLE_UPLOAD]]
23951 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public java.lang.String net.sourceforge.subsonic.ajax.TagService.setTags(int,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String)] with attributes [[ROLE_COVERART]]
23952 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
28120 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization completed in 23962 ms
28793 [main] INFO /subsonic - Initializing Spring FrameworkServlet 'subsonic'
28793 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization started
28796 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@f69643: display name [WebApplicationContext for namespace 'subsonic-servlet']; startup date [Sat Apr 30 22:32:37 GMT 2016]; parent: org.springframework.web.context.support.XmlWebApplicationContext@123d65
28797 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/subsonic-servlet.xml]
29036 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@f69643]: org.springframework.beans.factory.support.DefaultListableBeanFactory@12dc8c4
29253 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@12dc8c4: defining beans [leftController,artistsController,rightController,statusController,mainController,playlistController,playlistsController,importPlaylistController,topController,helpController,moreController,uploadController,lyricsController,allmusicController,podcastController,podcastChannelsController,internetRadioController,internetRadioStreamController,podcastChannelController,podcastReceiverAdminController,setMusicFileInfoController,shareManagementController,setRatingController,randomPlayQueueController,changeCoverArtController,nowPlayingController,starredController,searchController,settingsController,playerSettingsController,dlnaSettingsController,sonosSettingsController,shareSettingsController,musicFolderSettingsController,networkSettingsController,transcodingSettingsController,internetRadioSettingsController,podcastSettingsController,videoConversionSettingsController,generalSettingsController,advancedSettingsController,personalSettingsController,avatarUploadController,userSettingsController,passwordSettingsController,homeController,editTagsController,playQueueController,coverArtController,captionsController,avatarController,proxyController,statusChartController,userChartController,m3uController,streamController,hlsController,videoPlayerController,videoConverterController,externalPlayerController,downloadController,premiumSettingsController,multiController,wapController,restController,dbController,premiumSettingsValidator,userSettingsValidator,passwordSettingsValidator,urlMapping,messageSource,themeSource,themeResolver,viewResolver]; parent: org.springframework.beans.factory.support.DefaultListableBeanFactory@151e434
32366 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization completed in 3572 ms
32431 [main] INFO org.mortbay.log - Started SelectChannelConnector@192.168.1.10:4040
33168 [main] INFO org.mortbay.log - Started SslSocketConnector@192.168.1.10:4041
Subsonic running on: http://192.168.1.10:4040/subsonic
                and: https://192.168.1.10:4041/subsonic
33334 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
33373 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
33485 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[192.168.1.10:9412](local),objID:[0:0:0, 0]]]]
119631 [btpool0-2] INFO org.directwebremoting.log.startup - Starting: DwrServlet v3.0.0-FINAL on jetty-6.1.x / JDK 1.8.0_65 from Oracle Corporation at /subsonic
120812 [btpool0-2] INFO org.directwebremoting.log.startup - Starting: Using container abstraction org.directwebremoting.server.servlet2.Servlet24ContainerAbstraction
120861 [btpool0-2] INFO org.directwebremoting.servlet.UrlProcessor - Probably not an issue: the url:/gi.js (org.directwebremoting.gi.GiHandler) Handler is not available. This is only an problem if you wanted to use it.
121271 [btpool0-7] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
121271 [btpool0-4] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
121272 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
121272 [btpool0-6] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
121274 [btpool0-2] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
124647 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
124678 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
124710 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
124721 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
125730 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
129992 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
130009 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
131828 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
139996 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
140013 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
141956 [btpool0-4] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
153353 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
153460 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
164751 [btpool0-8] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
164824 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
164952 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
165170 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
165375 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
170692 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
177014 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
177030 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
177047 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
177065 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
177595 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
177669 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
182847 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
185036 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
186174 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
188705 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
188744 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
198751 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
198762 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
207053 [btpool0-8] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
This forum is blocking my ISP with their aggressive filtering, so I can only login via my phone. After all my contributions (and more than 2X the recommend donation), the site admin is unwilling to help. You can find me at SmallNetBuilder Forums.
MikeLegit
Re: v6.0 gives "Failed to find parameter: instanceId"
Postby MikeLegit » Sat Apr 30, 2016 11:00 pm
ok, rebooted the NAS server and it magically worked. Strange, but I will leave this post in case it may help others...
MikeLegit
Postby toolman » Sat Apr 30, 2016 11:36 pm
This is a known issue which has nothing to do with Subsonic, but with the browsercache.
Clearing the browsercache will solve this error as you will find in other topics.
Sometimes it just pays to search the forum...
toolman
Postby MikeLegit » Sun May 01, 2016 12:19 am
My post is the only post on the forum with that error that requires a QNAP NAS to be rebooted in order to resolve. There is now something to search for others. :roll: The clearing cache didn't work in this case, and if you had read the post closely, you would have seen that connections externally to subsonic including my phone app didn't work because the issue was with subsonic in a funct state from the upgrade, not the problem of a single computer browser.
Sometimes it just pays to read the post closely. :lol:
MikeLegit
