Web UI can't see song duration
Postby klatzke » Tue May 10, 2016 12:49 pm
Problem Description: When playing a song in the web UI, the length of the song is displayed as "Infinity:NaN:NaN"
Additionally, if I pause the song for a while and start playing again, it will skip to the next track after a few seconds. This does not happen if I only briefly pause.
This started when I installed 6.0 beta 2, and continued with 6.0.
Troubleshooting Steps: I've tried clearing my cache, I've tried multiple browsers. This only happens in Firefox if the song is longer than 8 minutes, it happens with all songs in Chrome, and it only happens on Windows. Mac and Linux machines do not experience this problem in Firefox or Chrome. This also does not happen in any apps I've tried.
Playback Application and version: Standard Web UI
Subsonic Version: 6.0 (build a7857c) – April 30, 2016
Server Version: jetty-6.1.x, java 1.8.0_25
Hardware Platform: Mac
Java Memory Limit: (105.0 MB / 141.5 MB)
Output from ffmpeg -i:
ffmpeg version 2.4.3 Copyright (c) 2000-2014 the FFmpeg developers
  built on Jun 25 2015 07:51:51 with Apple LLVM version 6.0 (clang-600.0.54) (based on LLVM 3.5svn)
  configuration: --prefix=/usr/local/Cellar/ffmpeg/2.4.3 --enable-shared --enable-pthreads --enable-gpl --enable-version3 --enable-nonfree --enable-hardcoded-tables --enable-avresample --cc=clang --host-cflags= --host-ldflags= --enable-libx264 --enable-libfaac --enable-libmp3lame --enable-libxvid --enable-vda
  libavutil      54.  7.100 / 54.  7.100
  libavcodec     56.  1.100 / 56.  1.100
  libavformat    56.  4.101 / 56.  4.101
  libavdevice    56.  0.100 / 56.  0.100
  libavfilter     5.  1.100 /  5.  1.100
  libavresample   2.  1.  0 /  2.  1.  0
  libswscale      3.  0.100 /  3.  0.100
  libswresample   1.  1.100 /  1.  1.100
  libpostproc    53.  0.100 / 53.  0.100
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x7f85ad00f000] stream 0, timescale not set
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Volumes/Artemis/iTunes/Music/Progressive/Opeth/2008 Watershed/03 The Lotus Eater.m4a':
  Metadata:
    major_brand     : M4A
    minor_version   : 0
    compatible_brands: M4A mp42isom
    creation_time   : 2009-06-24 19:56:22
    Encoding Params : vers
    iTunNORM        :  00001C0C 00001E2A 00008996 0000810F 00030E17 00034513 00008000 00008000 0005EC90 0002634C
    iTunes_CDDB_IDs : 7+A0B0C03FD2CB21A06E2D10254DC5ACF9+10643267
    album_artist    : Opeth
    disc            : 1/1
    gapless_playback: 0
    track           : 3/7
    artist          : Opeth
    album           : Watershed
    comment         :
    date            : 2008
    genre           : Progressive Metal
    lyrics          : Liquid is in your throat For hopeless delight After all you fell in love with death Life has aborted All you've had and all you became The night is calling, you pray forth  A barren waste is your land Crops they were sown to die  This skin is a mirror The eyes hover with ignorance Hell throb from your lips Sucked in and safe from the world of sleep  All years caring for a liar The barren drift road is winding higher You're a moth too close to the fire  You are stuck in a beautiful future Changing and waiting and seeking the truth of it all  Fleeting in sorrow Pushing your spirit away Seeking the weakness of dislike Whispered from the heart To be, we're all in the mourning, To despair  Cries out: "The restless will also... die."  Resurrection covered with death Drawing the life under one A fact tied to the earth The souls a victim, a follower  Oh, mother! (Incoherent growling) For us to see The blink of an eye  And the pride of a mother Drawn close in a mother's son And the love from a father Was used by a fa
    title           : The Lotus Eater
    encoder         : Encoded with Audirvana Plus
    composer        : Mikael Ã…kerfeldt
  Duration: 00:08:50.57, start: 0.000000, bitrate: 916 kb/s
    Stream #0:0(und): Audio: alac (alac / 0x63616C61), 44100 Hz, stereo, s16p, 912 kb/s (default)
    Metadata:
    Stream #0:1: Video: mjpeg, yuvj420p(pc, bt470bg), 750x750 [SAR 300:300 DAR 1:1], 90k tbr, 90k tbn, 90k tbc
Last ten log file lines:
[5/10/16 4:14:16 AM CDT]   WARN   NetworkService   Failed to create port forwarding.
[5/10/16 5:14:16 AM CDT]   WARN   NetworkService   Failed to create port forwarding.
[5/10/16 6:14:16 AM CDT]   WARN   NetworkService   Failed to create port forwarding.
[5/10/16 7:09:12 AM CDT]   INFO   TranscodeInputStream   Starting transcoder: /Library/Application Support/Subsonic/transcode/ffmpeg -i /Volumes/Artemis/iTunes/Music/Progressive/Opeth/2008 Watershed/01 Coil.m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
[5/10/16 7:12:24 AM CDT]   INFO   TranscodeInputStream   Starting transcoder: /Library/Application Support/Subsonic/transcode/ffmpeg -i /Volumes/Artemis/iTunes/Music/Progressive/Opeth/2008 Watershed/02 Heir Apparent.m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
[5/10/16 7:14:17 AM CDT]   WARN   NetworkService   Failed to create port forwarding.
[5/10/16 7:21:15 AM CDT]   INFO   TranscodeInputStream   Starting transcoder: /Library/Application Support/Subsonic/transcode/ffmpeg -i /Volumes/Artemis/iTunes/Music/Progressive/Opeth/2008 Watershed/01 Coil.m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
[5/10/16 7:21:18 AM CDT]   INFO   TranscodeInputStream   Starting transcoder: /Library/Application Support/Subsonic/transcode/ffmpeg -i /Volumes/Artemis/iTunes/Music/Progressive/Opeth/2008 Watershed/03 The Lotus Eater.m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
[5/10/16 7:30:09 AM CDT]   INFO   TranscodeInputStream   Starting transcoder: /Library/Application Support/Subsonic/transcode/ffmpeg -i /Volumes/Artemis/iTunes/Music/Progressive/Opeth/2008 Watershed/04 Burden.m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
[5/10/16 7:37:51 AM CDT]   INFO   TranscodeInputStream   Starting transcoder: /Library/Application Support/Subsonic/transcode/ffmpeg -i /Volumes/Artemis/iTunes/Music/Progressive/Opeth/2008 Watershed/05 Porcelain Heart.m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
klatzke
Re: Web UI can't see song duration
Postby klatzke » Tue Sep 13, 2016 1:42 pm
Just in case anyone comes across this with the same issue, I found out it was a network problem. I was using a custom URL for subsonic, and set up my router to point incoming port 80 to local port 4040 for subsonic. After some troubleshooting, I found that connections inside my network would display duration, but outside, it failed. Using my subsonic premium address worked, as did using my custom address specifying port 4040 (example.com:4040). It's a workaround, at least. Until I can figure out how to make the port forward work correctly, this solves the issue.
klatzke
Users browsing this forum: No registered users and 60 guests
