After upgrade to 6.0 files stop playing in the middle
Postby zeus163 » Tue May 17, 2016 3:16 pm
*I think I may have fixed it. You'll notice that my port forwarding fails (even though I believe it to be set up correctly). I have the premium package, but can't connect through my premium address. I can successfully connect though through my no-ip account. I went into the admin screen and changed the network settings to point to my no-ip address and now everything seems to be playing like it should be.
I used the 6.0 "war" package to upgrade. Everything seemed to upgrade fine on Subsonic which runs on my windows server 2012 r2 essentials except for a "failed to find paramter: instanceID" on one of my machines. I cleared my browser data history like I saw mentioned in another post here. that seemed to solve the cosmetic issues, however, songs don't play all the way through on the different machines I've tried streaming from. When I revert back to 5.3, everything is fine. I've tried the upgrade a few times, update the ffmpg files, and still have the issues.
*I upgrade again so that I could get the missing information needed.
Problem Description: After my upgrade, using the WAR package, songs don't play all the way through on the different machines I've tried streaming from. When I revert back to 5.3, everything is fine.
Troubleshooting Steps: I've tried the upgrade a few times, updated the ffmpeg files, and still have the issues.
Playback Application and version: Chrome and FireFox Browsers
Subsonic Version: 6.0 (build a7857c) – April 30, 2016
Server: Apache Tomcat/6.0.37, java 1.7.0_05, Windows NT (unknown) (250.2 MB / 719.7 MB)
Hardware Platform: Windows Server 2012R2 Essentials
Java Memory Limit: 1024
[5/19/16 1:16:11 PM PDT]   INFO   HsqlDaoHelper   Checking database schema.
[5/19/16 1:17:32 PM PDT]   INFO   HsqlDaoHelper   Done checking database schema.
[5/19/16 1:17:33 PM PDT]   INFO   SettingsService   Java: 1.7.0_05, OS: Windows NT (unknown)
[5/19/16 1:17:34 PM PDT]   INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Fri May 20 03:00:00 PDT 2016
[5/19/16 1:17:34 PM PDT]   INFO   UPnPService   Starting UPnP service...
[5/19/16 1:17:34 PM PDT]   INFO   VersionService   Resolved local Subsonic version to: 6.0
[5/19/16 1:17:34 PM PDT]   INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Thu May 19 13:22:34 PDT 2016
[5/19/16 1:17:37 PM PDT]   INFO   UPnPService   Disabling UPnP/DLNA media server
[5/19/16 1:17:37 PM PDT]   INFO   UPnPService   Starting UPnP service - Done!
[5/19/16 1:17:45 PM PDT]   WARN   NetworkService   Failed to create port forwarding.
[5/19/16 1:22:34 PM PDT]   INFO   PodcastService   Starting scheduled Podcast refresh.
[5/19/16 1:22:34 PM PDT]   INFO   PodcastService   Completed scheduled Podcast refresh.
[5/19/16 1:25:31 PM PDT]   INFO   BootstrapVerificationFilter   Servlet container: Apache Tomcat/6.0.37
[5/19/16 1:25:46 PM PDT]   INFO   SubsonicLdapBindAuthenticator   User 'Steve' successfully authenticated in LDAP. DN: CN=Steve,cn=Users,dc=SANDJ,dc=local
[5/19/16 1:25:50 PM PDT]   INFO   VersionService   Resolved latest Subsonic final version to: 6.0
[5/19/16 1:25:50 PM PDT]   INFO   VersionService   Resolved latest Subsonic beta version to: 6.0.beta2
[5/19/16 2:17:45 PM PDT]   WARN   NetworkService   Failed to create port forwarding.
zeus163
Re: After upgrade to 6.0 files stop playing in the middle
Postby Chupitos » Thu May 19, 2016 6:14 pm
I have the same issue after upgrading to version 6 standalone...
MP3 files are ok but if I try to listen to FLAC or M4A files the music stop after a few seconds.
Playback Application and version: Firefox browser
Subsonic Version:
License Subsonic Premium
Version 6.0 (build a7857c) – 30 avril 2016
Server Version: Serveur jetty-6.1.x, java 1.7.0_101, Linux (78,4 MB / 136,0 MB)
Hardware Platform: Debian GNU/Linux 7.8 x86_64
See the logs below
[19/05/16 19:58:42 CEST]    INFO   TranscodeInputStream   Starting transcoder: /var/subsonic/transcode/ffmpeg -i /home/subsonic/music/AcDc/Dirty Deeds Done Dirt Cheap/ACDC - Dirty Deeds Done Dirt Cheap - 01 - Dirty Deeds Done Dirt Cheap.flac -map 0:0 -b:a 320k -v 0 -f mp3 -
[19/05/16 19:58:42 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream mapping:
[19/05/16 19:58:42 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[19/05/16 19:58:42 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Press ctrl-c to stop encoding
[19/05/16 19:58:42 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 565kB time=24.08 bitrate= 192.1kbits/s
[19/05/16 19:58:43 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 1089kB time=46.47 bitrate= 192.0kbits/s
[19/05/16 19:58:43 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 1605kB time=68.49 bitrate= 192.0kbits/s
[19/05/16 19:58:44 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 2123kB time=90.59 bitrate= 192.0kbits/s
[19/05/16 19:58:44 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 2641kB time=112.69 bitrate= 192.0kbits/s
[19/05/16 19:58:45 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 3155kB time=134.61 bitrate= 192.0kbits/s
[19/05/16 19:58:45 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 3695kB time=157.65 bitrate= 192.0kbits/s
[19/05/16 19:58:46 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 4215kB time=179.85 bitrate= 192.0kbits/s
[19/05/16 19:58:46 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 4729kB time=201.77 bitrate= 192.0kbits/s
[19/05/16 19:58:47 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 5245kB time=223.76 bitrate= 192.0kbits/s
[19/05/16 19:58:47 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 5438kB time=231.99 bitrate= 192.0kbits/s
[19/05/16 19:58:47 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) video:0kB audio:5437kB global headers:0kB muxing overhead 0.003233%
[19/05/16 19:59:45 CEST]    INFO   TranscodeInputStream   Starting transcoder: /var/subsonic/transcode/ffmpeg -i /home/subsonic/music/AcDc/Dirty Deeds Done Dirt Cheap/ACDC - Dirty Deeds Done Dirt Cheap - 01 - Dirty Deeds Done Dirt Cheap.flac -map 0:0 -b:a 320k -v 0 -f mp3 -
[19/05/16 19:59:45 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream mapping:
[19/05/16 19:59:45 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[19/05/16 19:59:45 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Press ctrl-c to stop encoding
[19/05/16 19:59:46 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 567kB time=24.19 bitrate= 192.1kbits/s
[19/05/16 19:59:46 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 1091kB time=46.55 bitrate= 192.0kbits/s
[19/05/16 19:59:47 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 1610kB time=68.68 bitrate= 192.0kbits/s
[19/05/16 19:59:47 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 2130kB time=90.85 bitrate= 192.0kbits/s
[19/05/16 19:59:48 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 2650kB time=113.06 bitrate= 192.0kbits/s
[19/05/16 19:59:48 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 3166kB time=135.08 bitrate= 192.0kbits/s
[19/05/16 19:59:49 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 3706kB time=158.12 bitrate= 192.0kbits/s
[19/05/16 19:59:49 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 4228kB time=180.40 bitrate= 192.0kbits/s
[19/05/16 19:59:50 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 4742kB time=202.32 bitrate= 192.0kbits/s
[19/05/16 19:59:50 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 5260kB time=224.42 bitrate= 192.0kbits/s
[19/05/16 19:59:51 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 5438kB time=231.99 bitrate= 192.0kbits/s
[19/05/16 19:59:51 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) video:0kB audio:5437kB global headers:0kB muxing overhead 0.003233%
[19/05/16 20:04:00 CEST]    INFO   TranscodeInputStream   Starting transcoder: /var/subsonic/transcode/ffmpeg -i /home/subsonic/music/Aretha Franklin/This Is Jazz #34/Aretha Franklin - This Is Jazz #34 - 1 - Evil Gal Blues.m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
[19/05/16 20:04:00 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream mapping:
[19/05/16 20:04:00 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[19/05/16 20:04:00 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) Press ctrl-c to stop encoding
[19/05/16 20:04:00 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 485kB time=20.66 bitrate= 192.1kbits/s
[19/05/16 20:04:01 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 995kB time=42.42 bitrate= 192.1kbits/s
[19/05/16 20:04:01 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 1347kB time=57.44 bitrate= 192.0kbits/s
[19/05/16 20:04:02 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 1712kB time=73.04 bitrate= 192.0kbits/s
[19/05/16 20:04:02 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 1964kB time=83.77 bitrate= 192.0kbits/s
[19/05/16 20:04:03 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 2238kB time=95.48 bitrate= 192.0kbits/s
[19/05/16 20:04:03 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 2511kB time=107.13 bitrate= 192.0kbits/s
[19/05/16 20:04:04 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 3030kB time=129.25 bitrate= 192.0kbits/s
[19/05/16 20:04:04 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 3527kB time=150.49 bitrate= 192.0kbits/s
[19/05/16 20:04:05 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 3801kB time=162.17 bitrate= 192.0kbits/s
[19/05/16 20:04:05 CEST]    INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) video:0kB audio:3801kB global headers:0kB muxing overhead 0.007991%
Thanks for your help
Chupitos
Postby Chupitos » Thu May 19, 2016 6:59 pm
The problem is not Subsonic but Firefox...
Subsonic works fine with Chromium, the songs that stop with Firefox are playing normally with Chromium
I have a laptop (Xubuntu 14.04 (64-bit)) with Firefox 46.0.1 and Chromium Version 50.0.2661.102
Sorry I should have tested this before posting :oops:
Chupitos
Postby zeus163 » Thu May 19, 2016 9:24 pm
Chupitos wrote:The problem is not Subsonic but Firefox...
I use Chrome (Version 50.0.2661.102 m) at work and I have the issue still. I'm getting ready to post my log files, but they seem to look different then some of the examples that I've seen posted here. I once followed a guide using the Tomcat/WAR method, so maybe I'm missing something.
zeus163
Postby aoganesi » Fri Jun 10, 2016 6:42 am
I experienced the same issue after upgrading to 6. My assumption is that Web player is working differently with the default FLAC -> mp3 transcoding.
Here is my workaround:
  • Install the dedicated "flac" transcoder (on my QNAP: "ipkg install flac")
  • copy the file to the subsonic/transcode directory (check execute permissions)
  • remove flac from the default transcoding
  • add the following transcoding path: [Name="flac mp3", Convert from="flac", Convert to="mp3", Step1="flac --silent --decode --stdout %s". Step2="lame --silent -h -b %b -"]
aoganesi
Postby perrin666 » Wed Jul 06, 2016 3:27 pm
I have the same issue (also in Chrome) in Subsonic 6 (since reverted back to 5.3 until this is fixed). However, I also have the same problem in 5.3 when I use Jamstash, which also uses a HTML5 player instead of the Flash player, so I assume the bug is in the HTML5 player. I had the issue mostly with long songs (which I have a lot of) and I use MP3s only, no FLAC.
perrin666
Postby acroyear » Wed Jul 06, 2016 6:48 pm
Context: SubFire uses the html5 audio tag.
ok, I've never seen this in Chrome. Any time the playback cut out on me, it was due to a poor network connection at my office (the firewall changes/resets my external IP address/name regularly for security reasons - it avoids reverse-lookup attacks).
In Firefox, however, I have found that if I'm routing through the *.subsonic.org address, with a fixed-rate file (CBR), then the duration keeps changing with every bit of the buffer that arrives. The server is supposed to send a header to the stream request that gives the "range" (and the html5 audio tag pulls the duration out from there), but in the case of the redirect, it is losing that information. VBR (Variable bit rate files, like what you buy from Amazon) don't have this problem, because the duration is set as a property of the file format. Firefox does not do this when there is no redirect, as in, if I'm pointing directly to my server.
So since a song "ends" when the current time is > than what the tag sees as the duration, I can easily see the case that happen if your network connection isn't the greatest.
FLAC conversion usually generates fixed-rate files (at least, they do by the default transcoder in the settings). It may be possible to resolve it by making the transcoder produce VBR files. It may take longer to start (the file couldn't be served until it was completely converted), but it could resolve the cut-off. No promises.
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Postby dkl » Sat Jul 30, 2016 8:30 pm
I have the same trouble here, on a Rapsbian rapsberry 2. Upgrading to 6.0 makes files which are not native mp3 stop in the middle (flac, m4a) when using the web HTLM5 player. Native mp3 files work ok. Downgrading to 5.3 solves the problem (well, no HTML5 reader in 5.3 anyway, but the web player works OK). So I'm back in 5.3 for now.
I use Firefox as a client.
I have installed Subsonic 6.0 on another PC on Ubuntu 14.04 (fujitsu Esprimo desktop, i.e not a raspberry), and when using this server in 6.0, the problem does not appear, everything just works fine. So, there might be something incompatible between subsonic 6.0 and Raspbian? Or any HW issue with the RPI, but not in former versions like 5.3????
Should I try to give more memory to Java (150 currently). Would version 6.0 need much more memory that 5.3? Any clue?
I use ffmpeg for transcoding, with a link to installed up to date binary in/var/subsonic/transcode. And the settings for transcoding are strictly the same between 5.3 and 6.0. I don't see any errors in the logs.
Denis
dkl
