Playlists don't work (v6.0)
Postby arodgil2 » Sat May 21, 2016 6:22 am
Im using a Debian server.
My playlists are in /home/multimedia/playlists, in m3u format
My user in /etc/default/subsonic have the good privs to access to my playlists dir. (I've tested with root but the same problem occur)
I've declared my playlists directory in the application &, after, I've set the SUBSONIC_ARGS="--port=4040 --https-port=4041 --max-memory=200 --default-playlist-folder=/home/multimedia/playlists"
I've tested import a playlist with the application
Nothing work !
My resolution for now : Use Twonky, a non GPL application :-(
Have you another solution ?
arodgil2
Re: Playlists don't work (v6.0)
Postby Exrace » Sat May 21, 2016 6:19 pm
Check your subsonic log. Looks like a badpath/permissions issue.
Exrace
