regenerate playlist cover art
Postby Jägs » Wed May 25, 2016 6:50 pm
I been spending a lot of time reorganizing and retagging much of my music, which has resulted in adding (or re-adding) album artwork. Prior to this, I had established a number of playlists, each of which has cover artwork generated by Subsonic based on the artwork of the music in the playlist. That being the case, I have a number of playlists without actual cover artwork, some with one or more "corners" of the cover artwork missing, or some simply with the wrong artwork.
Is there a way to have Subsonic regenerate these, short of exporting the playlist, deleting it in Subsonic, and importing it again?
Jägs
Re: regenerate playlist cover art
Postby acroyear » Thu May 26, 2016 2:17 pm
actually, very simple, and I just did it (in 6.0, not sure if 5.3 will do it this way).
Just go to the playlist. Drag a file from position 5 or lower, one that is not in the cover art collage already, up into the first 4. Reload the playlist frame. Then drag it back into place and reload again (assuming the playlist order is important to you).
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Postby Jägs » Sat May 28, 2016 4:17 am
Brilliant, thanks!
Jägs
