Podcast episodes kicking back "Peer Not Authenticated" error
Postby TrezOne » Fri May 27, 2016 6:13 pm
Hi all,
Problem description: So I have TYT (The Young Turks) as one of the podcasts on my server and they made a change a while back to how they host their podcasts. Ever since the change, every episode is kicking back a "peer not authenticated" message when it attempts to download any episodes (I'm a member of TYT, so here's the URL with the pertinent parts censored: http://tytnetwork.gbox.com/playlist-4J5 ... xxxxxxxxx-).
Troubleshooting steps: Tried deleting and re-adding the podcast, adding it as an HTTPS link, removing the trailing dash from the URL, and upgrading from Subsonic 5.3 to 6.0. Issue still persists.
Subsonic Info:
License - Subsonic Premium (expires August 31, 2017)
Version - 6.0 (build a7857c) – April 30, 2016
Server - jetty-6.1.x, java 1.7.0_79, Linux (81.6 MB / 213.5 MB)
OS: Ubuntu 14.04 LTS
Sample output from log:
[2016-05-18 07:44:58,799] WARN PodcastService - Failed to download Podcast from http://tytnetwork.gbox.com/playlist-4J53xNUnhg/rss/offer-BJn8eV-z/JimGilmoreInterview.mp3?voucher=xxxxxxxxx
javax.net.ssl.SSLPeerUnverifiedException: peer not authenticated
   at sun.security.ssl.SSLSessionImpl.getPeerCertificates(SSLSessionImpl.java:421)
   at org.apache.http.conn.ssl.AbstractVerifier.verify(AbstractVerifier.java:126)
   at org.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:437)
   at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:180)
   at org.apache.http.impl.conn.ManagedClientConnectionImpl.open(ManagedClientConnectionImpl.java:294)
   at org.apache.http.impl.client.DefaultRequestDirector.tryConnect(DefaultRequestDirector.java:644)
   at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:479)
   at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:906)
   at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:805)
   at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:784)
   at net.sourceforge.subsonic.service.PodcastService.doDownloadEpisode(PodcastService.java:549)
   at net.sourceforge.subsonic.service.PodcastService.access$300(PodcastService.java:76)
   at net.sourceforge.subsonic.service.PodcastService$5.run(PodcastService.java:412)
   at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
   at java.util.concurrent.FutureTask.run(FutureTask.java:262)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
   at java.lang.Thread.run(Thread.java:745)
As a side note, elsewhere on the forums I saw that people managed to resolve similar issues via downgrading to openjdk7, which I'm already running (output is from sudo dpkg -l | egrep -i 'openjdk':
ii  openjdk-7-jre:amd64                 7u79-2.5.6-0ubuntu1.14.04.1             amd64        OpenJDK Java runtime, using Hotspot JIT
ii  openjdk-7-jre-headless:amd64        7u79-2.5.6-0ubuntu1.14.04.1             amd64        OpenJDK Java runtime, using Hotspot JIT (headless)
Any help is awesomely appreciated!
TrezOne
Re: Podcast episodes kicking back "Peer Not Authenticated" e
Postby mystery666 » Sun Sep 11, 2016 8:45 pm
I'm having the same problem as well. I'm new to podcasts and trying to listen to Serial through Subsonic. Here's the feed
http://feeds.serialpodcast.org/serialpodcast
mystery666
Postby crispygoth » Sun Nov 20, 2016 11:44 pm
Same issue for me with the feed at http://feeds.feedburner.com/mitternacht ... format=xml (tried Java versions 7 and 8)
Looking at the feed mentioned in the OP along with the above, it seems like they both link to HTTPS sites that require SNI, maybe that's it? According to https://issues.apache.org/jira/browse/HTTPCLIENT-1119 this was added to the Apache HttpClient in version 4.3.2, but if I peek inside the subsonic.war file I can see httpclient-4.2.4. Is there any chance of upgrading this so it'll support SNI?
crispygoth
Postby toolman » Mon Nov 21, 2016 6:28 am
@mystery666:
I'm now listening to a Serial podcast S02 "Episode 11: Present for Duty" without any problems in Subsonic.
Some lines out of my logfile after I configured Podcast:
[21-11-16 2:27:01 CET] WARN PodcastService Failed to resolve media file ID for podcast channel 'null': java.lang.NullPointerException
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S02 Episode 11: Present for Duty
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S02 Episode 10: Thorny Politics
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S02 Episode 09: Trade Secrets
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S02 Episode 08: Hindsight, Part 2
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S02 Episode 07: Hindsight, Part 1
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S01 Update: Day 03, Adnan Syed’s Hearing
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S01 Update: Day 02, Adnan Syed’s Hearing
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S02 Episode 06: 5 O'Clock Shadow
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S01 Update: Day 01, Adnan Syed’s Hearing
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S02 Episode 05: Meanwhile, in Tampa
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S02 Episode 04: The Captors
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S02 Episode 03: Escaping
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S02 Episode 02: The Golden Chicken
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S02 Episode 01: DUSTWUN
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S01 Episode 12: What We Know
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S01 Episode 11: Rumors
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S01 Episode 10: The Best Defense is a Good Defense
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S01 Episode 09: To Be Suspected
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S01 Episode 08: The Deal with Jay
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S01 Episode 07: The Opposite of the Prosecution
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S01 Episode 06: The Case Against Adnan Syed
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S01 Episode 05: Route Talk
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S01 Episode 04: Inconsistencies
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S01 Episode 03: Leakin Park
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S01 Episode 02: The Breakup
[21-11-16 2:27:03 CET] INFO PodcastService Created Podcast episode S01 Episode 01: The Alibi
[21-11-16 2:27:03 CET] INFO PodcastService Starting to download Podcast from https://dts.podtrac.com/redirect.mp3/do ... 02-e11.mp3
[21-11-16 2:28:45 CET] INFO PodcastService Downloaded 61866030 bytes from Podcast https://dts.podtrac.com/redirect.mp3/do ... 02-e11.mp3
[21-11-16 2:28:45 CET] INFO PodcastService Deleted old Podcast episode https://dts.podtrac.com/redirect.mp3/do ... 01-e01.mp3
[21-11-16 2:28:45 CET] INFO PodcastService Deleted old Podcast episode https://dts.podtrac.com/redirect.mp3/do ... 01-e02.mp3
[21-11-16 2:28:45 CET] INFO PodcastService Deleted old Podcast episode https://dts.podtrac.com/redirect.mp3/do ... 01-e03.mp3
[21-11-16 2:28:45 CET] INFO PodcastService Deleted old Podcast episode https://dts.podtrac.com/redirect.mp3/do ... 01-e04.mp3
[21-11-16 2:28:45 CET] INFO PodcastService Deleted old Podcast episode https://dts.podtrac.com/redirect.mp3/do ... 01-e05.mp3
[21-11-16 2:28:45 CET] INFO PodcastService Deleted old Podcast episode https://dts.podtrac.com/redirect.mp3/do ... 01-e06.mp3
[21-11-16 2:28:45 CET] INFO PodcastService Deleted old Podcast episode https://dts.podtrac.com/redirect.mp3/do ... 01-e07.mp3
[21-11-16 2:28:45 CET] INFO PodcastService Deleted old Podcast episode https://dts.podtrac.com/redirect.mp3/do ... 01-e08.mp3
[21-11-16 2:28:45 CET] INFO PodcastService Deleted old Podcast episode https://dts.podtrac.com/redirect.mp3/do ... 01-e09.mp3
[21-11-16 2:28:45 CET] INFO PodcastService Deleted old Podcast episode https://dts.podtrac.com/redirect.mp3/do ... 01-e10.mp3
[21-11-16 2:28:45 CET] INFO PodcastService Deleted old Podcast episode https://dts.podtrac.com/redirect.mp3/do ... 01-e11.mp3
[21-11-16 2:28:45 CET] INFO PodcastService Deleted old Podcast episode https://dts.podtrac.com/redirect.mp3/do ... 01-e12.mp3
[21-11-16 2:28:45 CET] INFO PodcastService Deleted old Podcast episode https://dts.podtrac.com/redirect.mp3/do ... 02-e01.mp3
[21-11-16 2:28:45 CET] INFO PodcastService Deleted old Podcast episode https://dts.podtrac.com/redirect.mp3/do ... 02-e02.mp3
[21-11-16 2:28:45 CET] INFO PodcastService Deleted old Podcast episode https://dts.podtrac.com/redirect.mp3/do ... 02-e03.mp3
[21-11-16 2:28:45 CET] INFO PodcastService Deleted old Podcast episode https://dts.podtrac.com/redirect.mp3/do ... 02-e04.mp3
No problems here.
Subsonic 6.0 (build 830afc) – 30 april 2016
Server jetty-6.1.x, java 1.8.0_111, Windows Server 2008 R2 (110,1 MB / 185,0 MB)
toolman
