Subsonic 6.0 - Failed to find Parameter: instanceld
Postby utbluesman » Mon Jun 13, 2016 8:50 pm
Afternoon all,
Just updated to Subsonic 6.0 and two problems have popped up.
First, any action on the web interface is met with a dialog window popping up that states "Failed to find parameter: instanceld (check server log for more info)".
This dialog window pops up when clicking on pretty much anything. Dismissing the popup allows Subsonic to continue on with the operation.
However, something is not right.
The second issue is that the Web Player just shows the circling arrow icon. Clicking on a song doesn't load it for the web player and doesn't play it.
Anyone having this issue? Any fixes?
Server:
Acer Aspire R3610
Win 7 Home Premium 64bit
Atom 330 CPU
4Gb RAM
Client:
Acer Veriton L4620G
Win 10 Pro 64bit
Intel Core i7-3770S
8Gb RAM
Google Chrome Version 41.0.2704.84m
utbluesman
Re: Subsonic 6.0 - Failed to find Parameter: instanceld
Postby powderedegg » Wed Jun 15, 2016 8:09 am
I'm getting the same problem too after upgrading from 6.0 beta to 6.0.
Looking in /var/subsonic/subsonic_sh.log
26555 [btpool0-6] INFO org.directwebremoting.log.startup - Starting: Using container abstraction org.directwebremoting.server.servlet2.Servlet24ContainerAbstraction
26563 [btpool0-6] INFO org.directwebremoting.servlet.UrlProcessor - Probably not an issue: the url:/gi.js (org.directwebremoting.gi.GiHandler) Handler is not available. This is only an problem if you wanted to use it.
26660 [btpool0-5] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
26662 [btpool0-3] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
26662 [btpool0-6] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
26869 [btpool0-4] ERROR org.directwebremoting.dwrp.Batch - Failed to find parameter: instanceId, enable debug logging to see more info.
powderedegg
Postby powderedegg » Thu Jun 16, 2016 9:10 am
I've come back to my installation this morning and it's working fine now.
powderedegg
Postby utbluesman » Thu Jun 16, 2016 9:49 am
Thanks for the follow up poweredegg.
I hadn't checked since I posted. Logged in this morning, and like you, the error message is gone and the web player is working correctly.
Odd behavior.
Wonder if I missed a reboot or if something updated.
Not sure what changed, but I'll call this one closed.
utbluesman
Users browsing this forum: No registered users and 101 guests
