Music won't immediately resume after pause
Postby PEC » Tue Jul 05, 2016 8:00 pm
Subsonic version: 6.0 (build a7857c) – April 30, 2016
Google Chrome 51.0.2704.103 (64-bit) on Mac OS X 10.11.5
When pausing in the middle of a song, when I go to resume, it plays about a second of music, then it cuts out (no sound) and hangs, and it takes anywhere from 30-120 seconds for audio to resume. Some caching problem perhaps? Did not have this problem on the previous stable release of Subsonic.
PEC
Re: Music won't immediately resume after pause
Postby perrin666 » Wed Aug 10, 2016 9:09 am
Same thing happens to me. Although it doesn't seem to resume at all after it hangs.
When the total time of the song is shown as Infinite:NaN:NaN, it doesn't even resume in the first place. Only way is to restart the song completely by clicking on the title in the playlist.
It also seems to only happen when you pause the song for a couple of minutes.
Update: I think I managed to fix it. First and foremost, the problem with the total song length being shown as Infinity:NaN:NaN was due to the transcoder. When I disabled it, the correct song length appeared. Then I tried running Subsonic in Incognito mode to see if it hangs there as well when resuming playback. It worked fine, so I tried disabling a bunch of extensions I no longer use, and now it works as it should.
Chrome version: 51.0.2704.103 m (64-bit) on Windows 7
perrin666
Users browsing this forum: No registered users and 55 guests
