Unable to access Subsonic w/personal URL via home network
Postby deep86 » Mon Jul 18, 2016 2:31 am
Any help you could offer would definitely be appreciated. I've got Subsonic running on a Raspberry Pi that is connected to my home network. In the last couple of days, I've noticed that while I'm able to use my personalized URL to access Subsonic while I'm out and about with no trouble, if I try to use the URL while I'm connected to my home network, I'm prompted to log in, and then I receive the following error in my browser:
This site can't be reached
107.137.66.83 refused to connect
ERR_CONNECTION_REFUSED
In my browser's address bar, the URL that is listed is as follows: http://107.137.66.83:4040/j_acegi_security_check
I've assigned my raspberry pi a static IP, and that's not it. In fact, if I enter the static IP into my browser, everything works fine. For some reason, the personalized URL is redirecting to the 107. IP address for some reason.
If any additional information could help, please let me know.
deep86
Re: Unable to access Subsonic w/personal URL via home networ
Postby alphawave7 » Mon Jul 18, 2016 2:36 am
Seems to be a recurring theme:
viewtopic.php?f=2&t=16775
Oh, and the personal SS addy is SUPPOSED to always forward to your public IP (107...).
Postby deep86 » Mon Jul 18, 2016 3:53 am
Thanks for replying. So since in my case I'm not able to use the personalized URL INSIDE my home network, but outside of it, any ideas as to what I should do? I haven't installed a new pi, all the same hardware, and I didn't make any changes with my router that I'm aware of. Would resetting the router possibly work?
deep86
Postby alphawave7 » Mon Jul 18, 2016 5:44 am
deep86 wrote:Thanks for replying. So since in my case I'm not able to use the personalized URL INSIDE my home network, but outside of it, any ideas as to what I should do? I haven't installed a new pi, all the same hardware, and I didn't make any changes with my router that I'm aware of. Would resetting the router possibly work?
Test your router by simply typing your public IP:4040, and if your lan browser cannot retrieve your local page, the router would be suspect. Perhaps a full factory reset (and re-opening 4040 port) will help, as well as any firmware upgrade if it has one available. Curious on make, model and revision of your router?
Postby acroyear » Mon Jul 18, 2016 7:36 pm
odd. yesterday i got that same security check error as well. i just rebooted my box (which i had to do anyways because of pending updates) and it went away.
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Users browsing this forum: No registered users and 60 guests
