Site Can't be Rached
Postby tdd8t » Wed Jul 20, 2016 9:55 am
Problem Description:
When I do to run the app ro restart it
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
Troubleshooting Steps:
Restarting Machine
Reinstalling subsonic
Changing Port Number on Subsonic Control Panel
Playback Application and version: This is from the browser running the software
Subsonic Version: Installed version 6.0
Server Version: Installed version 6.0
Hardware Platform: Windows Home Server
Java Memory Limit: 150M
tdd8t
Re: Site Can't be Rached
Postby Morley » Sat Jul 23, 2016 12:47 pm
spiralone wrote:ok so yeah. make sure to delete subsonic folder. start from scratch as i said before. tho your email cannot be used to recover password or username for old server address you can recover your license key with your old email once you remake your personal server and the affmountain wealthy affiliate review makes sense just like before. best of luck. and all praise to subsonic developer(s) for making the greatest app there is (along with anyone who successfully makes a winamp remote app [wmote :)] and hell even you protube formerly mctube)
I get the same error.
Morley
Postby ciencio » Wed Aug 10, 2016 1:59 am
Same error here.
I can't find anything charged, I restarted my server, checked the default, buttare can't sort it out.
Same error on Android device.
ciencio
Postby spiralon » Wed Aug 10, 2016 8:45 pm
Same error here. Waiting for resolution
spiralon
Postby knibbeje » Thu Aug 11, 2016 3:42 am
Same error here, can someone help? Is it related to version 6?
knibbeje
Postby alphawave7 » Thu Aug 11, 2016 4:26 am
Much like the Java update issue, we're now seeing M$ monthly Win updates cause a flurry of 503/corrupted database issues. This is likely caused by improper shut down of the service before updating. PLEASE make a back up of your virgin Subsonic database so you can recover from these issues when (not only if) they occur; otherwise, you will need to start fresh.
Postby knibbeje » Thu Aug 11, 2016 4:47 pm
alphawave, can you explain how to remedy this issue? I have no problems starting fresh, I have uninstalled multiple times and reinstalled. I tried version 6, version 5 and a version 4, no joy. Where can I delete any old corrupt files or databases? Isn't uninstalling taking care of that?
I have the latest version of Java, is that a problem?
I can't get the log in page to load in a browser at all due to the server error so I can't go in my settings and point to a different drive where my music resides or make any other setting changes. I need to get to log in at least as adminstrator to set things up again correct?
This is Win 10, I tried google, chrome, IE, no joy. I tried going to the services and right clicking the log in to allow access to network drives but that did not good. Right now my music is hosted on an external drive attached to the computer by way of a hard drive dock and a USB 3.0 cable.
knibbeje
Postby spiralon » Fri Aug 12, 2016 6:49 am
having same issues as the above user. i do not mind starting from scratch. how do i go about doing this. is this a stateside issue? some kind of regional thing? please help. i use subsonic every day multiple hours. if there is no remedy i would like to know this as well so as to quit relying on it
spiralon
Postby spiralon » Fri Aug 12, 2016 7:04 am
ok. i think i understand starting from scratch now lol. i deleted the subsonic folder in C: and i was able to open the login page. but my username would not work. i had to log in as admin/admin (username/password). what happened to my subscription? must i really cancel my payment on my credit card and make a new account?
spiralon
Postby spiralon » Fri Aug 12, 2016 7:44 am
ok so yeah. make sure to delete subsonic folder. start from scratch as i said before. tho your email cannot be used to recover password or username for old server address you can recover your license key with your old email once you remake your personal server and then use it just like before. best of luck. and all praise to subsonic developer(s) for making the greatest app there is (along with anyone who successfully makes a winamp remote app [wmote :)] and hell even you protube formerly mctube)
spiralon
Postby knibbeje » Fri Aug 19, 2016 4:38 pm
I finally got it solved. The problem was that when you uninstall subsonic it goes to your Program files (x86) folder and removes the subsonic stuff from there. But in a separate folder back in your C: folder there is a folder names subsonic that seems to have the Java files or something. You have to manually delete that folder, then probably restart, or at least delete that folder and then reinstall Subsonic and then it worked. yes, i did have to set things up again with my own account, user name, password, and then retrieve my premium license and re-enter that and then we were off to the races.
Can the admin team/developer not make it so that when you use the windows uninstall process that it deletes all traces of subsonic including that stand alone folder in the C: directory that stay put and causes conflict?
knibbeje
