Play ts flux
Play ts flux
Postby bibi » Wed Jul 27, 2016 2:55 pm
First of all, thanks for the last version of subsonic, it's great to have an html5 player to play audio and video !
I would like to play video http streams, which are encoded in mpegts for the video part.
For that, i try to create an encoder which will be launch when i try to play a special format.
For instance, i created an video.video file, i add the .video to the video extension and i finally add this encoder (hls encoder) :
ffmpeg -i http://192.168.0.11:3000/T-0-498-1031 -s %wx%h -v 1 -b:v %bk -maxrate %bk -bufsize 256k -map 0:0 -map 0:%k -f mpegts -c:v libx264 -preset superfast -c:a aac -b:a 96k -threads 0 -
but when i try to play the video.video file, it tells me :
hlsjs: Video file not found
https://88.165.157.12/subsonic/hls/hls.m3u8?id=48245&player=1&auth=643663849&bitRate=1000&bitRate=200&bitRate=300&bitRate=400&bitRate=500&bitRate=700&bitRate=1200&bitRate=1500&bitRate=1700&bitRate=2000&bitRate=2500&bitRate=3000
And i cant find anything about this issue in the logfile...
I also tried to play the http stream as an internet TV but i can only get audio ^^.
Does somebody have an idea ?
Bibi
bibi
Users browsing this forum: No registered users and 63 guests
