trouble setting up networking on new Ubuntu server
Postby jonsaddles » Tue Aug 02, 2016 9:01 pm
Hi all,
Wondering if anyone can help. I have just setup a new media & file server running Ubuntu 16.04 and installed SS with no problems however when I try to connect from outside of my home network I get
"Connection failed
The server could be joined but required additional information could no be retrieved
Make sure you entered a valid BubbleUPnP Server connection URL and not your Media Server or NAS URL"
I have tried connecting using my static ip address and the .subsonic.org address but get the same result and ufw is allowing incoming connections on 4040 & 80
I'm sure this is something silly I've missed but I'm going round in circles.
jonsaddles
Re: trouble setting up networking on new Ubuntu server
Postby jonsaddles » Fri Aug 05, 2016 7:05 am
Doing some more checking I've found even on my internal network I can only connect with the firewall (ufw) turned off allowing ports 4040 & 80 through doesn't work.
No change on accessing from outside, still get the same error message.
Can anyone offer some advice please?
jonsaddles
Postby mrdrew » Fri Sep 02, 2016 9:43 pm
check out portforward http://portforward.com/ for help on opening up ports on your router.
http://www.canyouseeme.org/ is really good for checking to see if there's a service operating on an open port. Good for testing when you're at home, and need to see if your server is accessible from outside your network (not at home).
mrdrew
Users browsing this forum: No registered users and 60 guests
