Logging In
Logging In
Postby doloroso » Tue Mar 31, 2009 12:44 pm
Hi, I just installed subsonic on windows vista and when I try to create my user name and password by going to http://localhost/ the page doesn't load...I have tried using different ports but no luck
doloroso
Postby jonathanroz » Tue Mar 31, 2009 12:57 pm
I believe on Windows you should havea subsonic control panel running in your task bar. Look down by your PC clock and it should look like a little submarine.
Right click on it and it should give you an option to open subsonic. If that is not working then right click and open the control panel. Try to change the port and restart subsonic.
If you are still having issues I would verify that Windows Firewall is allowing that port, but I dont know if that is really an issue with local access.
jonathanroz
Postby doloroso » Tue Mar 31, 2009 8:38 pm
How can I check to see if my firewall is allowing the port(s)?...Is this the only thing that I have to check for concerning the firewall, like to I have to see if the firewall is blocking subsonic too?
doloroso
Postby jonathanroz » Tue Mar 31, 2009 9:46 pm
jonathanroz
