Subsonic 6.0 Database 12,907 entries limitation?
Postby markle » Wed Aug 17, 2016 5:47 am
Problem Description: Media Scanner Service won't scan past 12,907 entries. No media files from K (partly J) through to Z, subsonic only shows empty folders. Media files on the server exceed 25K.
Troubleshooting Steps: De-mounted, remounted media folders, re-scanned. Rebooted FreeNAS. Purchased Subsonic Premium subscription.
Playback Application and version: Google Chrome Version 52.0.2743.116 m
Subsonic Version: 6.0 (build a7857c) – April 30, 2016 on FreeNAS device
Server Version: jetty-6.1.x, java 1.7.0_76, FreeBSD (95.4 MB / 147.0 MB)
Hardware Platform: FreeNAS-9.10-STABLE-201606270534 (dd17351)
Java Memory Limit: n/a?
Problem Filename: n/a
Output from ffmpeg -i:
bash: ffmpeg: command not found
Last ten log file lines:
[8/17/16 3:22:58 PM AEST]   INFO   MediaScannerService   Scanned media library with 5500 entries.
[8/17/16 3:22:58 PM AEST]   INFO   MediaScannerService   Scanned media library with 5750 entries.
[8/17/16 3:22:58 PM AEST]   INFO   MediaScannerService   Scanned media library with 6000 entries.
[8/17/16 3:22:58 PM AEST]   INFO   MediaScannerService   Scanned media library with 6250 entries.
[8/17/16 3:22:59 PM AEST]   INFO   MediaScannerService   Scanned media library with 6500 entries.
[8/17/16 3:22:59 PM AEST]   INFO   MediaScannerService   Scanned media library with 6750 entries.
[8/17/16 3:22:59 PM AEST]   INFO   MediaScannerService   Scanned media library with 7000 entries.
[8/17/16 3:22:59 PM AEST]   INFO   MediaScannerService   Scanned media library with 7250 entries.
[8/17/16 3:23:00 PM AEST]   INFO   MediaScannerService   Scanned media library with 7500 entries.
[8/17/16 3:23:00 PM AEST]   INFO   MediaScannerService   Scanned media library with 7750 entries.
[8/17/16 3:23:00 PM AEST]   INFO   MediaScannerService   Scanned media library with 8000 entries.
[8/17/16 3:23:01 PM AEST]   INFO   MediaScannerService   Scanned media library with 8250 entries.
[8/17/16 3:23:01 PM AEST]   INFO   MediaScannerService   Scanned media library with 8500 entries.
[8/17/16 3:23:01 PM AEST]   INFO   MediaScannerService   Scanned media library with 8750 entries.
[8/17/16 3:23:02 PM AEST]   INFO   MediaScannerService   Scanned media library with 9000 entries.
[8/17/16 3:23:02 PM AEST]   INFO   MediaScannerService   Scanned media library with 9250 entries.
[8/17/16 3:23:02 PM AEST]   INFO   MediaScannerService   Scanned media library with 9500 entries.
[8/17/16 3:23:02 PM AEST]   INFO   MediaScannerService   Scanned media library with 9750 entries.
[8/17/16 3:23:03 PM AEST]   INFO   MediaScannerService   Scanned media library with 10000 entries.
[8/17/16 3:23:03 PM AEST]   INFO   MediaScannerService   Scanned media library with 10250 entries.
[8/17/16 3:23:03 PM AEST]   INFO   MediaScannerService   Scanned media library with 10500 entries.
[8/17/16 3:23:03 PM AEST]   INFO   MediaScannerService   Scanned media library with 10750 entries.
[8/17/16 3:23:04 PM AEST]   INFO   MediaScannerService   Scanned media library with 11000 entries.
[8/17/16 3:23:04 PM AEST]   INFO   MediaScannerService   Scanned media library with 11250 entries.
[8/17/16 3:23:04 PM AEST]   INFO   MediaScannerService   Scanned media library with 11500 entries.
[8/17/16 3:23:04 PM AEST]   INFO   MediaScannerService   Scanned media library with 11750 entries.
[8/17/16 3:23:04 PM AEST]   INFO   MediaScannerService   Scanned media library with 12000 entries.
[8/17/16 3:23:05 PM AEST]   INFO   MediaScannerService   Scanned media library with 12250 entries.
[8/17/16 3:23:05 PM AEST]   INFO   MediaScannerService   Scanned media library with 12500 entries.
[8/17/16 3:23:05 PM AEST]   INFO   MediaScannerService   Scanned media library with 12750 entries.
[8/17/16 3:23:05 PM AEST]   INFO   MediaScannerService   Scanned media library with 12907 entries.
[8/17/16 3:23:05 PM AEST]   INFO   MediaScannerService   Marking non-present files.
[8/17/16 3:23:05 PM AEST]   INFO   MediaScannerService   Marking non-present artists.
[8/17/16 3:23:05 PM AEST]   INFO   MediaScannerService   Marking non-present albums.
[8/17/16 3:23:05 PM AEST]   INFO   MediaScannerService   Completed media library scan.
[8/17/16 3:23:06 PM AEST]   INFO   PlaylistService   Starting playlist import.
[8/17/16 3:23:06 PM AEST]   INFO   PlaylistService   Completed playlist import.
markle
Re: Subsonic 6.0 Database 12,907 entries limitation?
Postby markle » Wed Aug 17, 2016 5:57 am
Additional Information;
I have two separate media files; one for music and one for movies.
Interestingly both media folders only show media files up to J; K through to Z are just empty folders with no media files showing. Unusual.
markle
Postby markle » Wed Aug 17, 2016 8:47 am
Okay.
I had another go. I'm not that bright or smart but this is what I did;
1. In settings/media folders I unenabled all media folders.
2. did a clean-up database
3. re-scanned media folders
4. enabled media folders
5. re-scanned media folders
Seemed to work thus far with over 25K media files now contained in the database.
Weird huh?
markle
Postby toolman » Sat Aug 20, 2016 2:03 am
I.ve been using Subsonic for several years now and allthough I had some database-issues in previous versions, they never were related to exceeding a certain limit of records or entries.
I know run Subsonic 6 and my inventory shows:
2.799 artists
10.441 albums
141.694 songs.
So I do not think that there are limitations on the number of entries in the database.
Unfortunally your solution to solve yout problem is indeed the quickest way to resolve database-issues.
This can be annoying if you have written comments in Subsonic.
toolman
