Cover art not processed
Postby santivdk » Mon Aug 29, 2016 2:11 pm
I have recently moved subsonic to a Window-based VPS and everything seems to run smoothly, with one exception, the cover art is not displaying in the browser version. It's all there, because I do see it in the Android app I use (Dsub), but in the browser, I get the following error whenever I try to change the artwork:
WARN CoverArtController Failed to process cover art C:\inetpub\vhosts\h2604923.stratoserver.net\music\Fugees\The Score\Folder.jpg: java.lang.NoClassDefFoundError: Could not initialize class sun.java2d.Disposer
It does seem to be Java related, but I cannot figure out what the problem could be. Any advice?
Kind regards,
Santi
santivdk
Re: Cover art not processed
Postby toolman » Mon Aug 29, 2016 3:09 pm
The only thing I could think of is that the Java-installation on your server is in some way corrupt.
Perhaps removing all the java-installations on your VPS and reïnstalling the latest version could help.
I would however advice on stopping the subsonic-service during the uninstallation and installation of Java.
Succes.
toolman
Postby santivdk » Wed Aug 31, 2016 12:49 pm
And right you were! It worked, thansk very much.
Kind regards,
Santi
santivdk
Users browsing this forum: No registered users and 77 guests
