Error 500: ConflictInMappingEntry
Postby fenrir0wulf » Wed Aug 31, 2016 12:43 am
Thanks Microsoft. So since some windows updates the service has completely stopped working on any computer but the host. When I try connecting with the other computers, i can see that the ip address it tries to connect to a wrong address (tries to go on a 196 ip, my network is on 172). Host is running Windows Server 2012 R2. Here's the log the app gives me. Also, uninstalling and removing all files then reinstalled did not work. The app worked before, and since not even on my internal network it works, i'm guessing it's the system. Currently trying to put the app on a Windows 8.1 VM with a bridged network.
[2016-08-30 20:16:28,794] WARN NetworkService - Failed to create port forwarding.
java.lang.Exception: 500 Internal Server Error: Error: ConflictInMappingEntry (HTTP response was: 500 Internal Server Error)
at net.sourceforge.subsonic.service.upnp.ClingRouter.addPortMappingImpl(ClingRouter.java:116)
at net.sourceforge.subsonic.service.upnp.ClingRouter.addPortMapping(ClingRouter.java:89)
at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.execute(NetworkService.java:151)
at net.sourceforge.subsonic.service.NetworkService$Task.run(NetworkService.java:318)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.runAndReset(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
fenrir0wulf
Re: Error 500: ConflictInMappingEntry
Postby fenrir0wulf » Wed Aug 31, 2016 3:27 am
Alright so some development. Only the computers on my internal network can't access it. If it's from the outside, it seems to work, at least partly. But in any cases, the problem is the host, not the app. And I've already uninstalled java and subsonic and whatnot and nothing does so I'm just going to wipe and restart the machine.
fenrir0wulf
Postby fenrir0wulf » Fri Sep 02, 2016 3:12 am
Alright, more developpement. Still getting the error, but the service works fine. Don't really know what the cause of the error is, seems to be something with either java or a windows update because I just did a complete wipe and reinstall. But it works. Yay?
fenrir0wulf
Users browsing this forum: No registered users and 62 guests
