Changing the NIC that Subsonic binds to in Ubuntu
Postby jpeach » Tue Sep 06, 2016 7:53 pm
I am using ubuntu 16.04 and I have multiple NIC (Network Interface cards) in my computer. Subsonic is binding to the first NIC, how do I get it to bind to a different one?
jpeach
Re: Changing the NIC that Subsonic binds to in Ubuntu
Postby jpeach » Tue Sep 06, 2016 9:12 pm
I found a couple of answers.
At the linux level you can use network name spaces as described here:
http://unix.stackexchange.com/questions ... -interface
Another approach is to use LD_PRELOAD to capture the network bind operation as described here:
http://superuser.com/questions/241178/h ... -processes
Or, by far the easiest is to use a directive that is supported by subsonic. You edit the file:
/etc/default/subsonic
and in the SUBSONIC_ARGS parameter you add --host=HOST_IP
See:
/usr/share/subsonic/subsonic_sh for details
jpeach
