Error
Error
Postby skaopolo » Mon Sep 12, 2016 3:22 pm
Hi
On my disks i've different part for my music, I've Classical on one, Rock on the other one, and Blue, Jazz and the others on a other disk. The permissions are the same for all with chmod 0775 with the same owner and group.
For Classical and Rock it's ok but not for the others.
I let you the message after clean of the data base :
Message PreparedStatementCallback; SQL [select top 1 id from artist where not present]; out of memory; nested exception is java.sql.SQLException: out of memory
Java version Oracle Corporation 1.8.0_101
Operating system Linux 4.4.0-36-generic
Server jetty-6.1.x
Memory Used 28 of 132 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select top 1 id from artist where not present]; out of memory; nested exception is java.sql.SQLException: out of memory
at org.springframework.jdbc.core.JdbcTemplate.queryForList(JdbcTemplate.java:768)
at net.sourceforge.subsonic.dao.AbstractDao.queryForInt(AbstractDao.java:132)
at net.sourceforge.subsonic.dao.ArtistDao.expunge(ArtistDao.java:179)
at net.sourceforge.subsonic.controller.MusicFolderSettingsController.expunge(MusicFolderSettingsController.java:73)
at net.sourceforge.subsonic.controller.MusicFolderSettingsController.formBackingObject(MusicFolderSettingsController.java:58)
at org.springframework.web.servlet.mvc.AbstractFormController.getErrorsForNewForm(AbstractFormController.java:358)
at org.springframework.web.servlet.mvc.AbstractFormController.showNewForm(AbstractFormController.java:338)
at org.springframework.web.servlet.mvc.AbstractFormController.handleRequestInternal(AbstractFormController.java:278)
at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:59)
Caused by: java.sql.SQLException: out of memory
... 65 more
Thank for an answer
Michel
skaopolo
Re: Error
Postby sindre_mehus » Mon Sep 19, 2016 6:37 pm
Try to increase the memory limit of Subsonic. See instructions on http://www.subsonic.org/pages/installation.jsp
Users browsing this forum: No registered users and 58 guests
