Radio streaming to android app?
Postby LuKeNuKuM » Tue Sep 20, 2016 2:25 pm
hi all,
i've got a couple of audio streams set up within the subsonic server, they work well (once i found compatible sources!) http://www.radionomy.com/ works well if anyone is looking!
but the problem is, i was hoping that i'd be able to stream-the-stream to the android app but i find no mention of the Radio/TV within the app. is this by design or am i missing something?! it would be great to listen to the the same radio stations whilst i'm on the go! :D
cheers,
Luke
LuKeNuKuM
Re: Radio streaming to android app?
Postby acroyear » Tue Sep 20, 2016 2:47 pm
(shameless plug 8) ) Subfire has internet radio support for Android. Works both Chrome and Firefox, but for radio streaming I've found that Firefox is a little more stable on 4G (both are about equal on wifi). I listen to "Muppet Central Radio" pretty regularly.
http://p.subfireplayer.net/
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Postby LuKeNuKuM » Thu Sep 22, 2016 8:21 pm
thanks for the tip! ideally i'd like to keep it all within the android app... but hey, you can't always get what you want!
LuKeNuKuM
Postby acroyear » Thu Sep 22, 2016 8:32 pm
Actually, I can...but only by writing my own app (which is a reason I did that). 8)
Joe Shelby
acroyear
Postby daneren2005 » Thu Sep 22, 2016 10:30 pm
DSub will also support Internet Radio Streaming in the near future. I already have it coded in just not sure when it will go out in an official release.
Postby LuKeNuKuM » Wed Oct 19, 2016 12:57 pm
daneren2005 wrote:DSub will also support Internet Radio Streaming in the near future. I already have it coded in just not sure when it will go out in an official release.
i think it must have now gone out :-) i've had D-sub for a while but not used it frequently. it's now got support and works great - thank you! it also seems to have solved a problem i was having with tracks randomly stopping and playing the next track early which is bonus.
LuKeNuKuM
Users browsing this forum: No registered users and 105 guests
