Subsonic encountered an internal error - Any ideas?
Postby krushr » Thu Sep 22, 2016 10:44 am
Copy / Paste from Error that shows up in the left hand frame:
Error
Exception   java.lang.NullPointerException
Message   null
Java version   Oracle Corporation 1.8.0_91
Operating system   Windows 10 10.0
Server   jetty-6.1.x
Memory   Used 47 of 122 MB
Stack trace   java.lang.NullPointerException
   at net.sourceforge.subsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:191)
   at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:120)
   at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:175)
   at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:60)
   at net.sourceforge.subsonic.service.MusicIndexService.getMusicFolderContent(MusicIndexService.java:70)
   at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:63)
   at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:59)
krushr
Re: Subsonic encountered an internal error - Any ideas?
Postby krushr » Thu Sep 22, 2016 10:49 am
Worked fine last night - machine not shut down but does a scan in the night as normal. Error shows up now in the morning. :(
krushr
Postby krushr » Thu Sep 22, 2016 3:28 pm
Slightly different error now on the left hand side pane
Error
Exception   org.springframework.dao.TransientDataAccessResourceException
Message   PreparedStatementCallback; SQL [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; S1000 General error java.lang.NullPointerException in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
Server   jetty-6.1.x
Memory   Used 75 of 138 MB
Stack trace   org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; S1000 General error java.lang.NullPointerException in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
   at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:81)
   at net.sourceforge.subsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:182)
Caused by: java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
   ... 63 more
krushr
Postby alphawave7 » Thu Sep 22, 2016 7:04 pm
S1000 is a database error usually after an improper shutdown/Java auto updates. You need to rebuild db. Search forum for S1000 error for details.
Users browsing this forum: No registered users and 107 guests
