All I want to do is hear my music on the home network
Postby knightrider » Sun Apr 05, 2009 12:56 pm
Sorry if this has been covered before.......
I'm just trying to set up Subsonic as a home jukebox player. (no internet)
I currently have 5 computers networked together (simple switcher) which share a dial-up connection on one computer. (modem in one computer shares with the other 4 via ethernet)
I have no idea how to set this up so that music playing from one computer can be heard on the others.
Could someone please explain how to set this up with the correct subnet/ip addresses/ports and firewall settings?
Win XP SP3.
Thank you so much.
-Knightrider
knightrider
Postby donpearson » Sun Apr 05, 2009 6:52 pm
subsonic will not do that, you will need some funky program to do that or even better just get some wireless speakers http://www.maplin.co.uk/Module.aspx?ModuleNo=33457
:wink:
Facebook Group:
donpearson
Postby knightrider » Sun Apr 05, 2009 7:06 pm
so you're saying that i can't use subsonic to stream audio over my intranet and just block the port to the internet? I thought you could use the software to stream over an intranet.
knightrider
Postby jigsaw » Sun Apr 05, 2009 9:52 pm
Yes, you can use Subsonic to stream audio only in your house. I think what donpearson meant was that Subsonic is not designed for what you explicitly requested: "how to set this up so that music playing from one computer can be heard on the others".
Basically you don't play music on the server itself, but stream to each client which connect to Subsonic and start up a playlist. The exception to this is the Jukebox-feature, which allows you to control the playlist on the server. This only applies to the speakers directly attached to the server though ( maybe not what you're asking for.. ).
So if you simply would like all of your music to be stored at one server and accessible only from your local network it's a simple firewall rule ( e.g. only allow 192.168.0.0/16 to connect to Subsonic ).
Every client will have to control their own playlist though.
Does this cover your requirements at all?
jigsaw
Postby knightrider » Sun Apr 05, 2009 10:27 pm
sadly, no. I already have access to my music HD shared on the network. Infact, I use Traktor DJ Studio which allows sync over the network which is basically what i want, but the playlists have to be identical.
I'm sure this is a very useful software, just not what I'm looking for.
knightrider
jukebox?
Postby BrianDelShasta » Mon Apr 06, 2009 5:18 am
Jigsaw, has the jukebox feature been implemented already and I'm just missing it? Or are you talking about a feature in an upcoming release?
BrianDelShasta
Re: jukebox?
Postby jigsaw » Mon Apr 06, 2009 6:18 pm
BrianDelShasta wrote:Jigsaw, has the jukebox feature been implemented already and I'm just missing it? Or are you talking about a feature in an upcoming release?
Hmm.. After looking over the forum again I realize there's not actually a jukebox-feature in subsonic. I know I read about it and I was sure it already was implemented, but it seems I was mistaken.. The closes I found was that Sindre was talking about looking into JLayer as a server-side, in-process Jukebox ( here's the forum link: http://forum.subsonic.org/forum/viewtopic.php?t=1188 )
Sorry about that BrianDelShasta, but stay tuned and/or bump the thread.. You might get a hit :)
Edit: Knew I read something about it.. Looky here: http://forum.subsonic.org/forum/viewtopic.php?t=1644
To-be released in Subsonic 3.7 :)
jigsaw
