HTTP ERROR 503 Service unavailable
Postby danoneer » Fri Oct 07, 2016 2:31 pm
After upgrading to subsonic 6, and then try to log onto subsonic I get the message: HTTP Error 503. Service unavailable.
I use Subsonic with Media Monkey to organize my music on a Windows 7 Professional computer.
I have uninstalled and re-installed. I have re-downloaded the program. I have checked router settings..Please help.
danoneer
Re: HTTP ERROR 503 Service unavailable
Postby Mog666 » Sat Oct 29, 2016 7:00 pm
I am also having this problem.
Problem Description:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
Troubleshooting Steps: uninstal and reinstal
Playback Application and version: isub on ios and windows phone
Subsonic Version: 6.0
Server Version: cannot access the web interface, see above error message.
Hardware Platform: Windows 8
Java Memory Limit: 150
Problem Filename: No connection to server at all
Please advise what I should try to resolve.
Mog666
Postby MikeLegit » Sat Nov 05, 2016 3:43 pm
Subsonic corrupts its database occasionally and the only solution is to delete it. You can save your settings file however it's a PITA since it takes time to do. And it always happens when I am away from my home. I sure hope Sindre can address at some point. :(
This forum is blocking my ISP with their aggressive filtering, so I can only login via my phone. After all my contributions (and more than 2X the recommend donation), the site admin is unwilling to help. You can find me at SmallNetBuilder Forums.
MikeLegit
Postby Mog666 » Sun Nov 27, 2016 1:29 pm
What do i have to delete? As per above have already tried uninstalling.
Mog666
Postby MikeLegit » Mon Nov 28, 2016 3:49 am
You delete your DB folder, which then creates a new DB on service startup. Might want to move it to a temp folder rather than delete, just in case that's not what you wanted. Be aware you'll lose everything as far as settings and stars. :?
As a side note, I removed my podcasts and haven't had a lick of database trouble for several weeks.
-MH
MikeLegit
Postby billraff » Fri Dec 16, 2016 11:19 pm
Is there a known issue with Podcasts causing db corruption? The reason I ask is I've not had any db problems until just today a few hours after enabling a few podcasts. Had to disable to even get the server to start back up again. I'm still seeing podcast errors in the log file though. Will probably just recreate the db from scratch since I unable to do anything from the podcast tab.
billraff
Postby toolman » Fri Dec 16, 2016 11:41 pm
As fas as I know it's an issue which some users have experienced. Whether it is a known issue I don't know.
Since Sindre said that there'll be an updated version of Subsonic coming soon which contains some bug fixes, perhaps this issue will be adressed too.
toolman
Postby Mog666 » Fri Dec 23, 2016 6:37 pm
I cannot find any files left behind when I have uninstalled, if there is database files I need to delete also please tell me where they are. Fresh install has not worked.
I am not concerned with keeping settings I just want it to work and I will go from there.
Mog666
Postby toolman » Fri Dec 23, 2016 8:45 pm
After uninstalling make sure that the folder where you installed Subsonic is really deleted.
I once uninstalled Subsonic from the folder C:\Subsonic and reinstalled it in a different folder C:\SubsonicV6, only to find that the database files were still present in the C:\subsonic folder and the new subsonic-installation used the database in that folder.
By default the database file is located in Subsonic\DB folder.
toolman
Postby Mog666 » Sat Dec 24, 2016 10:08 am
Thanks for all your help, I searched but for some reason c:\subsonic did not appear. I deleted that this time and seems to be working better.
Mog666
Postby Stormcloud » Sun Dec 25, 2016 5:13 pm
I started having this problem today and tried reinstalling subsonic and deleting all old app data but i am still receiving the error and cannot get to my localhost:4040.
Any other suggestions.
Windows 7.
Stormcloud
Postby toolman » Mon Dec 26, 2016 11:24 am
Does Subsonic-service start Ok?
No firewall-issues?
Did you configure Podcasts? ( Seems that that's a sure way to get your database corrupt.)
Running the latest version of Oracle Java?
You could try:
- Uninstall Subsonic.
- Check for any leftover Subsonic folders after uninstalling and delete them.
- Uninstall Java
- Restart your pc.
- Install Subsonic. ( Java will be installed)
I'm sorry you have all these issues trying to get Subsonic running, and I really don't understand what the problem is. I've installed Subsonic dozens of times and it always ran smoothly after installing.
toolman
Postby Stormcloud » Mon Dec 26, 2016 12:48 pm
It was running perfectly up until yesterday.
I have port 4040 forwarded, the service was running and had no problems. I have tried uninstalling, deleting all app data including the DB folder, and then reinstalled. No luck.
Stormcloud
Postby toolman » Tue Dec 27, 2016 12:56 am
Ok, But does the subsonic service start on your new installation?
Did you reboot your pc?
Did you clear the internet cache of the device you're using to connect to Subsonic?
Can you log in to Subsonic using http://localhost:4040 on the machine that's running Subsonic?
toolman
Postby Exrace » Sat Dec 31, 2016 1:03 pm
There are known issues with the upgrade to 6.0 Final.
I am still running the beta due to the installer blowing up my DB and setup on a Windows 2012 R2 setup.
I don't want to lose my DB.
6.0.beta2 (build ef60a8) – March 20, 2016
Issue has to do with how the installer cleans up from previous version.
I understand clean installs are OK with 6.0 Final but you have to make sure no traces are left.
I am happy with beta2...but hoping for a new years release. ;)
Exrace
