Premium "yourname.subsonic.org" Setup How
Postby unholyone » Sat Oct 08, 2016 5:14 pm
I want to buy a premium subscription lifetime. It says that I would get my own "yourname.subsonic.org".
I emailed subsonic at mail@subsonic.org and have received no reply for days.
How would I set that up when I subscribe?
Do I get to choose my name?
Can I change my name at a later point?
Thank yo so much for your time and help.
Best regards,
Charles
unholyone
Re: Premium "yourname.subsonic.org" Setup How
Postby mitrailer » Sun Oct 09, 2016 12:12 am
Hi
The address "yourname.subsonic.org" only redirects your dynamic IP in order to connect to your server. You can edit only the "yourname" part. Once you install subsonic go to "settings -> Network" to edit the address. I don't recommend to change "yourname" constantly
mitrailer
Postby unholyone » Sun Oct 09, 2016 12:57 am
Ok so I do all the setup for it in the server settings. And subsonic.org takes care of the rest?
It will continue to work even when my ISP changes the IP address as it does at times?
unholyone
Postby mitrailer » Mon Oct 10, 2016 4:02 pm
Yes and yes.
Note that after 30 day you have to pay for using subsonic outside your home
mitrailer
Postby unholyone » Mon Oct 10, 2016 4:19 pm
If I buy a lifetime subscription then I will be able to connect to subsonic outside my home for life correct??
unholyone
Postby mitrailer » Mon Oct 10, 2016 4:56 pm
Yes sir, that's correct
mitrailer
Postby unholyone » Mon Oct 10, 2016 5:05 pm
Thank you so much for all your help. :)
unholyone
Postby mitrailer » Mon Oct 10, 2016 5:30 pm
I forgot to tell that you need to open de 4040 port (or the port where you installed subsonic) on your router to connect to your server outside your home
mitrailer
Postby unholyone » Mon Oct 10, 2016 6:11 pm
Ok. Thanks will make sure I do.
unholyone
