Auto or Bulk Playlist Import
Postby Oc9nBd9s » Tue Oct 11, 2016 5:49 pm
Does anyone know of a way to setup a task/script to auto import playlists in a folder or a way to do a bulk import of them manually? Doing them one at a time thru the GUI is a bit cumbersome. I have a script running daily exporting them from iTunes to a folder. Would like to make them available in an automated or easier way in SubSonic also. Appreciate any suggestion and apologize if this has been answered already,
Oc9nBd9s
Re: Auto or Bulk Playlist Import
Postby G8DHE » Wed Oct 12, 2016 9:57 am
What's wrong with the "Import Playlists from" in Settings|Genereal, which is scanned each night and anything in there is imported ?
Geoff G8DHE
Version 6.0 Beta 2
G8DHE
Postby Oc9nBd9s » Wed Oct 12, 2016 12:58 pm
THANK YOU!!! I looked through settings a couple of times thinking it has to be in there somewhere and just completely missed it. Thank you!!!!
Oc9nBd9s
Postby Jägs » Mon Oct 31, 2016 4:51 pm
Is there a way to trigger this manually? I was having problems with playback, so I completely reinstalled it and want to import the playlists en masse right away, rather than waiting for Subsonic to do it in the morning.
Jägs
Postby toolman » Tue Nov 01, 2016 12:55 am
The only way to trigger playlist import is to start a folder scan.
toolman
Postby Jägs » Tue Nov 01, 2016 2:09 am
toolman wrote:The only way to trigger playlist import is to start a folder scan.
That worked, thanks!
Jägs
