Unsuccessful mobile streaming via Android App
Postby unamused » Tue Oct 18, 2016 4:15 pm
Problem Description: After many years of successful mobile streaming, my mobile streaming does not work. Android, LGG3 - I cannot get songs to download while on my home network or not. Songs stay stuck at "downloading - 0 B"
Troubleshooting Steps: I have downloaded the latest version of Subsonic, uninstalled and reinstalled the Android app.
Playback Application and version: Android App version 4.4
Subsonic Version: 6.0 (build 830afc) – April 30, 2016
Server Version: jetty-6.1.x, java 1.7.0_51, Windows 7 (93.9 MB / 145.0 MB)
Hardware Platform: Windows 7 Home Premium
Java Memory Limit: 150MB
Last ten log file lines:
[10/18/16 3:29:08 AM EDT]   INFO   NetworkService   Successfully forwarding port 8080.
[10/18/16 4:29:08 AM EDT]   INFO   NetworkService   Successfully forwarding port 8080.
[10/18/16 5:29:08 AM EDT]   INFO   NetworkService   Successfully forwarding port 8080.
[10/18/16 6:29:08 AM EDT]   INFO   NetworkService   Successfully forwarding port 8080.
[10/18/16 7:29:08 AM EDT]   INFO   NetworkService   Successfully forwarding port 8080.
[10/18/16 8:29:08 AM EDT]   INFO   NetworkService   Successfully forwarding port 8080.
[10/18/16 8:33:52 AM EDT]   INFO   PodcastService   Starting scheduled Podcast refresh.
[10/18/16 8:33:52 AM EDT]   INFO   PodcastService   Completed scheduled Podcast refresh.
[10/18/16 9:29:08 AM EDT]   INFO   NetworkService   Successfully forwarding port 8080.
[10/18/16 10:29:09 AM EDT]   INFO   NetworkService   Successfully forwarding port 8080.
[10/18/16 11:29:09 AM EDT]   INFO   NetworkService   Successfully forwarding port 8080.
Any help is greatly appreciated. I had a friend try on his phone as well with no luck. This one just has me stumped. Thanks.
unamused
Re: Unsuccessful mobile streaming
Postby toolman » Tue Oct 18, 2016 10:00 pm
Did you try to connect to your server using a webbrowser?
Can you log in?
Are there songs in the library?
Can you play songs from your webbrowser?
Perhaps updating Java to Version 8 Update 111 might help?
Perhaps an issue with your router?
Ever tried to delete the current portmapping in your router, rebooting it and configuring the portmapping again?
toolman
Postby unamused » Wed Oct 19, 2016 6:05 pm
toolman wrote:Did you try to connect to your server using a webbrowser?
Can you log in?
Yes, I can connect on my phone via a webbrowser (Chrome) and play songs.
The app works in every way other than streaming. I can log in, refresh the media
updating Java has no effect.
unamused
Re: Unsuccessful mobile streaming via Android App
Postby unamused » Sat Oct 22, 2016 7:09 pm
any thoughts?
still can't get this to work.
unamused
Postby toolman » Sat Oct 22, 2016 7:57 pm
I read somewhere on this forum that sometimes the problem is the portmapping in your router. The procedure would be to delete all portmappings in your router to your Subsonic-server, rebooting the router and configuring the portmappings again.
I never let Subsonic configure the portmappings but did it myself.
That's the only thing that comes to mind at this time.
toolman
Postby unamused » Tue Oct 25, 2016 2:58 pm
holy crap it finally works.
Strange that the portmapping would randomly become an issue when it never had been before.
thanks
unamused
Postby toolman » Tue Oct 25, 2016 7:07 pm
Happy to hear the problem is solved. Thank you for letting us know.
Enjoy your Subsonic.
toolman
Postby unamused » Sat Nov 19, 2016 3:02 pm
aaand it doesn't work yet again.
deleted and redid the port mapping, no luck.
unbelievable.
It's incredibly frustrating that this worked for many years, then there were some "upgrades" and it works like dogpiss now.
unamused
Postby toolman » Sat Nov 19, 2016 3:17 pm
Since it has worked, I suggest you check the Ip-configuration of your subsonic-server.
Can you log in locally on the server?
Did you try a portscan? http://www.t1shopper.com/tools/port-scan/
Does the portmapping point to the correct -ip-adress?
Did you reboot your router?
Anything in the logfiles?
toolman
Postby unamused » Sat Nov 19, 2016 6:49 pm
toolman wrote:Since it has worked, I suggest you check the Ip-configuration of your subsonic-server.
yes
yes
yes
yes
no
[11/19/16 1:48:22 PM EST]   INFO   HsqlDaoHelper   Checking database schema.
[11/19/16 1:48:34 PM EST]   INFO   HsqlDaoHelper   Done checking database schema.
[11/19/16 1:48:34 PM EST]   INFO   SettingsService   Java: 1.8.0_111, OS: Windows 7
[11/19/16 1:48:34 PM EST]   INFO   VersionService   Resolved local Subsonic version to: 6.0
[11/19/16 1:48:35 PM EST]   INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Sun Nov 20 03:00:00 EST 2016
[11/19/16 1:48:35 PM EST]   INFO   UPnPService   Starting UPnP service...
[11/19/16 1:48:35 PM EST]   INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Sat Nov 19 13:53:35 EST 2016
[11/19/16 1:48:35 PM EST]   INFO   UPnPService   Disabling UPnP/DLNA media server
[11/19/16 1:48:35 PM EST]   INFO   UPnPService   Starting UPnP service - Done!
[11/19/16 1:48:43 PM EST]   INFO   BootstrapVerificationFilter   Servlet container: jetty-6.1.x
[11/19/16 1:48:43 PM EST]   INFO   VersionService   Resolved latest Subsonic final version to: 6.0
[11/19/16 1:48:43 PM EST]   INFO   VersionService   Resolved latest Subsonic beta version to: 6.0.beta2
[11/19/16 1:48:45 PM EST]   INFO   NetworkService   Successfully forwarding port 8080.
unamused
Postby toolman » Sat Nov 19, 2016 9:54 pm
Can you acces your server from within your local network?
What does Subsonic say about your network status?
Under Settings >> Network does it say Status: Successfully registered web address. ?
And one more question: Do you have subscriptions to podcasts?
It seems that that can corrupt your database which leads to all sorts of errors and problems.
toolman
Postby unamused » Sun Nov 20, 2016 2:54 pm
I can view the artist and file list, refresh, search, etc on my phone from within and out of my local network. the only thing that does not work is streaming. I can access everything perfectly on the computer.
I have no podcast subscriptions
unamused
Postby toolman » Sun Nov 20, 2016 7:59 pm
Do you have a way to check if streaming via any webbrowser works? Edge, Firefox, Chrome Safari?
If that's working fine I guess the error / problem lies in the android app.
toolman
Postby unamused » Wed Nov 23, 2016 12:49 pm
toolman wrote:Do you have a way to check if streaming via any webbrowser works? Edge, Firefox, Chrome Safari?
The phone webbrowser works fine for streaming.
I suppose my next step is to remove/reinstall the app. again.
unamused
Postby toolman » Wed Nov 23, 2016 2:08 pm
I understand. It can be frustrating if you're seemingly in an endless loop of installing, removing and reïnstalling an app to get things working.
IS there no alternative to the Android-app?
toolman
