Getting Intermittent Error when Selecting From Index View
Postby dgood54 » Fri Oct 21, 2016 12:32 am
When I click on the A-Z Index icon, all artists in my library are listed, grouped by the first letter of the artist (as it should). However, when I click one of those artists, I'm getting an error much more often than not.
Here's the error text I've copied:
Message PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
Java version Oracle Corporation 1.8.0_111
Operating system Windows 10 10.0
Server jetty-6.1.x
Memory Used 94 of 145 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:81)
at net.sourceforge.subsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:165)
at net.sourceforge.subsonic.service.MediaFileService.checkLastModified(MediaFileService.java:137)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:163)
at net.sourceforge.subsonic.controller.MainController.getMediaFiles(MainController.java:185)
at net.sourceforge.subsonic.controller.MainController.handleRequestInternal(MainController.java:70)
at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:59)
Caused by: java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
... 62 more
dgood54
