m4a songs with wrong duration don't play until the end
Postby Bescu » Thu Nov 24, 2016 12:41 pm
I have a problem with my m4a files in Subsonic 6.0 : they don't have the good duration and so they don't play until the end (ex : 1:57 instead of 5:02)
In my Subsonic log I have these errors :
[2016-11-24 10:43:20,802] WARN StreamController - Unknown duration for 2016-11-02 - Les Deux Guitares. Unable to estimate transcoded size.
[2016-11-24 10:43:20,821] INFO TranscodeInputStream - Starting transcoder: /var/subsonic/transcode/ffmpeg -i /home/documents/mresibois/files/Répét/Enregistrements/2016-11-02 - Les Deux Guitare.m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
My transcoding settings are classical :
ffmpeg -i %s -map 0:0 -b:a %bk -v 0 -f mp3 -
And when I try it manually it's working well and the output mp3 is read with the correct duration in Subsonic.
/var/subsonic/transcode/ffmpeg -i "/home/documents/mresibois/files/Répét/Enregistrements/2016-11-02 - Les Deux Guitares.m4a" -map 0:0 -b:a 320k -v 0 -f mp3 "/home/documents/mresibois/files/Répét/Enregistrements/test.mp3"
Has someone an idea?
Thank you!
Bescu
Bescu
Re: m4a songs with wrong duration don't play until the end
Postby msalzbrenner » Tue Jan 10, 2017 7:58 pm
I'm having this same issue but with oga files. The android app handles playback just fine, but the web browser player doesn't want to play the entire song.
[2017-01-10 13:36:28,221] WARN StreamController - Unknown duration for The Runaways - Cherry Bomb. Unable to estimate transcoded size.
[2017-01-10 13:36:28,232] INFO TranscodeInputStream - Starting transcoder: /var/subsonic/transcode/ffmpeg -i /media/RemoteStorage/Music/Runaways/The Runaways - Cherry Bomb.oga -map 0:0 -b:a 320k -v 0 -f -
Anyone else running into this?
msalzbrenner
Postby jps2041 » Thu Jan 19, 2017 6:35 pm
I am also hitting this with Subsonic v6
6.0 (build a7857c) – April 30, 2016
[1/19/17 12:25:55 PM CST] INFO TranscodeInputStream Starting transcoder: /var/subsonic/transcode/ffmpeg -i /gfs/audio_share/media/incoming/busta/from_EH_vol_1/MF Doom/MM...Food/01 Beef Rapp.aiff -map 0:0 -b:a 320k -v 0 -f mp3 -
[1/19/17 12:26:01 PM CST] WARN StreamController Unknown duration for 01 Beef Rapp. Unable to estimate transcoded size.
jps2041
