Web interface don't play with new transcode parameters
Postby Ojetepelon » Wed Dec 07, 2016 9:46 pm
Problem Description: When I change the transcode settings I'm not able to play any file with browser player, keep loading until it stop to do it. (but if I play it with my mobile it works like a charm).
Troubleshooting Steps: I tried to uncheck the "active transcodings" to the player that I don't want to have transcode, but it didn't work.
Playback Application and version: Standard Subsonic web interface.
Subsonic Version: 6.0 (build a7857c) – April 30, 2016.
Subsonic Server Version: jetty-6.1.x, java 1.8.0_111, Linux (57.1 MB / 132.5 MB).
Hardware Platform: Ubuntu 16.10 (but with windows I have the same kind of problem).
Java Memory Limit: 200Mb
Problem Filename: All, it dont play anything by web interface.
Output from ffmpeg -i: I'll paste it but it don't show any error with playback in log, just don't play, you'll only see the correct transcode from subsonic to my mobile.
Transcoder & Downsampling line: ffmpeg -i %s -map 0:0 -c:a aac -b:a %bk -f adts -
[12/7/16 10:32:42 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 2082kB time=00:00:52.05 bitrate= 327.6kbits/s speed=6.82x
[12/7/16 10:32:42 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 2237kB time=00:00:55.96 bitrate= 327.4kbits/s speed=6.87x
[12/7/16 10:32:43 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 2395kB time=00:00:59.95 bitrate= 327.2kbits/s speed=6.93x
[12/7/16 10:32:43 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 2532kB time=00:01:03.39 bitrate= 327.3kbits/s speed=6.92x
[12/7/16 10:32:44 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 2687kB time=00:01:07.29 bitrate= 327.2kbits/s speed=6.97x
[12/7/16 10:32:44 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 2821kB time=00:01:10.63 bitrate= 327.2kbits/s speed=6.95x
[12/7/16 10:32:45 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 2980kB time=00:01:14.62 bitrate= 327.1kbits/s speed=6.99x
[12/7/16 10:32:45 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 3115kB time=00:01:17.97 bitrate= 327.3kbits/s speed=6.97x
[12/7/16 10:32:46 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 3267kB time=00:01:21.78 bitrate= 327.2kbits/s speed= 7x
[12/7/16 10:32:46 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 3419kB time=00:01:25.58 bitrate= 327.3kbits/s speed=7.02x
[12/7/16 10:32:47 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 3565kB time=00:01:29.21 bitrate= 327.3kbits/s speed=7.02x
[12/7/16 10:32:47 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 3715kB time=00:01:32.92 bitrate= 327.5kbits/s speed=7.04x
[12/7/16 10:32:48 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 3873kB time=00:01:36.92 bitrate= 327.3kbits/s speed=7.07x
[12/7/16 10:32:48 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 4028kB time=00:01:40.82 bitrate= 327.3kbits/s speed= 7.1x
[12/7/16 10:32:49 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 4179kB time=00:01:44.62 bitrate= 327.2kbits/s speed=7.11x
[12/7/16 10:32:49 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 4328kB time=00:01:48.34 bitrate= 327.2kbits/s speed=7.12x
[12/7/16 10:32:50 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 4482kB time=00:01:52.24 bitrate= 327.1kbits/s speed=7.13x
[12/7/16 10:32:50 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 4638kB time=00:01:56.14 bitrate= 327.1kbits/s speed=7.15x
[12/7/16 10:32:51 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 4799kB time=00:02:00.23 bitrate= 327.0kbits/s speed=7.18x
[12/7/16 10:32:51 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 4957kB time=00:02:04.22 bitrate= 326.9kbits/s speed= 7.2x
[12/7/16 10:32:52 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 5111kB time=00:02:08.12 bitrate= 326.8kbits/s speed=7.22x
[12/7/16 10:32:52 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 5257kB time=00:02:11.75 bitrate= 326.9kbits/s speed=7.22x
[12/7/16 10:32:53 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 5407kB time=00:02:15.46 bitrate= 327.0kbits/s speed=7.22x
[12/7/16 10:32:53 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 5557kB time=00:02:19.18 bitrate= 327.1kbits/s speed=7.22x
[12/7/16 10:32:54 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 5677kB time=00:02:22.15 bitrate= 327.2kbits/s speed=7.18x
[12/7/16 10:32:54 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 5806kB time=00:02:25.31 bitrate= 327.3kbits/s speed=7.16x
[12/7/16 10:32:55 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 5945kB time=00:02:28.74 bitrate= 327.4kbits/s speed=7.15x
[12/7/16 10:32:55 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 6098kB time=00:02:32.55 bitrate= 327.4kbits/s speed=7.16x
[12/7/16 10:32:56 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 6250kB time=00:02:36.36 bitrate= 327.4kbits/s speed=7.17x
[12/7/16 10:32:56 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 6397kB time=00:02:40.07 bitrate= 327.4kbits/s speed=7.17x
[12/7/16 10:32:57 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 6546kB time=00:02:43.79 bitrate= 327.4kbits/s speed=7.17x
[12/7/16 10:32:57 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 6690kB time=00:02:47.41 bitrate= 327.4kbits/s speed=7.17x
[12/7/16 10:32:58 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 6836kB time=00:02:51.03 bitrate= 327.4kbits/s speed=7.17x
[12/7/16 10:32:58 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 6991kB time=00:02:54.93 bitrate= 327.4kbits/s speed=7.18x
[12/7/16 10:32:59 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 7149kB time=00:02:58.93 bitrate= 327.3kbits/s speed= 7.2x
[12/7/16 10:32:59 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 7304kB time=00:03:02.83 bitrate= 327.3kbits/s speed=7.21x
[12/7/16 10:33:00 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 7459kB time=00:03:06.73 bitrate= 327.2kbits/s speed=7.22x
[12/7/16 10:33:00 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 7617kB time=00:03:10.72 bitrate= 327.2kbits/s speed=7.23x
[12/7/16 10:33:01 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 7775kB time=00:03:14.72 bitrate= 327.1kbits/s speed=7.24x
[12/7/16 10:33:01 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 7933kB time=00:03:18.71 bitrate= 327.0kbits/s speed=7.26x
[12/7/16 10:33:02 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 8067kB time=00:03:22.06 bitrate= 327.1kbits/s speed=7.24x
[12/7/16 10:33:02 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 8212kB time=00:03:25.68 bitrate= 327.1kbits/s speed=7.24x
[12/7/16 10:33:03 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 8368kB time=00:03:29.58 bitrate= 327.1kbits/s speed=7.24x
[12/7/16 10:33:03 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 8514kB time=00:03:33.20 bitrate= 327.1kbits/s speed=7.24x
[12/7/16 10:33:04 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 8668kB time=00:03:37.10 bitrate= 327.1kbits/s speed=7.25x
[12/7/16 10:33:04 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 8804kB time=00:03:40.72 bitrate= 326.7kbits/s speed=7.24x
[12/7/16 10:33:05 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 8849kB time=00:03:42.02 bitrate= 326.5kbits/s speed=7.16x
[12/7/16 10:33:05 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) size= 8900kB time=00:03:43.30 bitrate= 326.5kbits/s speed=7.16x
[12/7/16 10:33:05 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) video:0kB audio:8834kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.744230%
[12/7/16 10:33:05 PM CET]   INFO   InputStreamReaderThread   (/var/subsonic/transcode/ffmpeg) [aac @ 0xbc7f400] Qavg: 1863.010
Ojetepelon
