Help - Seems like something got currupt
Postby brokenbricks » Fri Dec 09, 2016 3:31 pm
Problem Description: all of a sudden i am only showing a few albums. I can't scan media folders as it dies after only a few hundred.
Troubleshooting Steps: rebooted server, stopped and started services.
Playback Application and version: 6.0 (build 830afc) – April 30, 2016
Subsonic Version: 6.0 (build 830afc) – April 30, 2016
Server Version: jetty-6.1.x, java 1.8.0_31, Windows Server 2012 (44.2 MB / 93.7 MB)
Hardware Platform: Windows Server
Java Memory Limit:
Problem Filename: n/a
Output from ffmpeg -i: (If you open a command prompt and type 'ffmpeg -i <filename>' what is the output? Ideally put this in a "code" block)
Last ten log file lines:
[12/7/16 7:59:00 PM EST] INFO NetworkService Successfully forwarding port 8080 and port 4443.
[12/7/16 9:03:17 PM EST] INFO NetworkService Successfully forwarding port 8080 and port 4443.
[12/7/16 10:07:33 PM EST] INFO NetworkService Successfully forwarding port 8080 and port 4443.
[12/7/16 11:11:49 PM EST] INFO NetworkService Successfully forwarding port 8080 and port 4443.
[12/8/16 12:16:05 AM EST] INFO NetworkService Successfully forwarding port 8080 and port 4443.
[12/8/16 1:20:22 AM EST] INFO NetworkService Successfully forwarding port 8080 and port 4443.
[12/8/16 2:24:38 AM EST] INFO NetworkService Successfully forwarding port 8080 and port 4443.
[12/8/16 3:00:02 AM EST] INFO MediaScannerService Starting to scan media library.
[12/8/16 3:00:03 AM EST] ERROR MediaScannerService Failed to scan media library.
brokenbricks
Re: Help - Seems like something got currupt
Postby toolman » Sat Dec 10, 2016 10:36 am
Does the Subsonic admin account have privileges on your mediafolders?
Did you check the Windows-permissions on your mediafolders?
Is the Subsonic-service account running under an account with full privileges on the mediafolders?
toolman
Postby brokenbricks » Sun Dec 11, 2016 5:08 pm
Thanks for the reply. No changes have been made on the server and I am logging in with the same account I have been for a few years now. I am a premium subscriber (not sure if that matters).
This happened to me a year or so back and I think I had to start over from scratch which would be pretty bad at this point.
Thanks.
brokenbricks
Postby toolman » Sun Dec 11, 2016 9:21 pm
I hope you still checked these things.
Could it be that your Java-installation has gone corrupt?
I would try the next thing:
Stop the Subsonic service, remove and reinstall Java and then restart Subsonic.
If that doesn't help you could try to install Subsonic again in the same folder. But make sure to copy the database folder to another location for back-up.
toolman
Postby brokenbricks » Wed Dec 21, 2016 8:03 pm
It looks like it is the DB that is corrupt. 2nd time in a year or so this has happened. Is there any "fixes" for this besides re-install?
brokenbricks
Postby toolman » Wed Dec 21, 2016 9:01 pm
Move the content of the DB-folder to another temporary folder
Start the Subsonic Service,
Subsonic will rebuild the database, but next you'll have to reconfigure Subsonic from scratch:
Mediafolders. users, networksettings. Everything.
From what I've been reading here it seems that subscriptions to podcasts could be the reason for your database to get corrupt.
toolman
