Bug Report
Bug Report
Postby EwoudCP » Mon Dec 12, 2016 9:45 am
So I'm quite happy with Subsonic so far. I've got it set up on an old netbook with BunsenLabs Linux at home.
Recently I switched from using a (now-failing) NAS to my netbook's local HDD to store my music. Apart from the playlists ("missing files"), the switch went smoothly. Until today.
This morning I tried logging in from work, and Subsonic gave this error:
Exception   org.springframework.jdbc.BadSqlGrammarException
Message   PreparedStatementCallback; bad SQL grammar [select id, name, type, username, ip_address, auto_control_enabled, last_seen, cover_art_scheme, transcode_scheme, dynamic_ip, technology, client_id from player where id=?]; nested exception is java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: "Z’f» Ϻ“[ùTÀª"
Java version   Oracle Corporation 1.7.0_111
Operating system   Linux 3.16.0-4-amd64
Server   jetty-6.1.x
Memory   Used 89 of 135 MB
Stack trace   org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [select id, name, type, username, ip_address, auto_control_enabled, last_seen, cover_art_scheme, transcode_scheme, dynamic_ip, technology, client_id from player where id=?]; nested exception is java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: "Z’f» Ϻ“[ùTÀª"
   at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:97)
   at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:97)
   at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:163)
   at net.sourceforge.subsonic.dao.PlayerDao.getPlayerById(PlayerDao.java:88)
   at net.sourceforge.subsonic.service.PlayerService.getPlayerById(PlayerService.java:174)
   at net.sourceforge.subsonic.service.PlayerService.getPlayer(PlayerService.java:93)
   at net.sourceforge.subsonic.service.PlayerService.getPlayer(PlayerService.java:63)
   at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:68)
   at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:59)
Caused by: java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: "Z’f» Ϻ“[ùTÀª"
   at org.hsqldb.jdbc.jdbcPreparedStatement.setParameter(Unknown Source)
   at org.hsqldb.jdbc.jdbcPreparedStatement.setString(Unknown Source)
   at org.springframework.jdbc.core.StatementCreatorUtils.setValue(StatementCreatorUtils.java:335)
   at org.springframework.jdbc.core.StatementCreatorUtils.setParameterValueInternal(StatementCreatorUtils.java:217)
   at org.springframework.jdbc.core.StatementCreatorUtils.setParameterValue(StatementCreatorUtils.java:145)
   at org.springframework.jdbc.core.ArgPreparedStatementSetter.setValues(ArgPreparedStatementSetter.java:51)
   at org.springframework.jdbc.core.JdbcTemplate$1.doInPreparedStatement(JdbcTemplate.java:646)
   ... 64 more
Music is unavailable, not from the browser nor any app (DSub, Jamstash).
Currently I'm still at work, so I can't restart the program (no SSH access to the netbook). I'll do so when I get home just to be sure.
But as a programmer myself, this seemed like a bug you wouldn't want to ignore (garbled strings in SQL queries are never good).
EwoudCP
Re: Bug Report
Postby EwoudCP » Mon Dec 12, 2016 9:50 am
I was about to check the version of my Subsonic server (6.0, build a7857c) when everything started working again. It appears the problem persisted for about 30 minutes before being corrected.
I'll leave this topic here regardless, it may contain useful information.
EwoudCP
