Can't Create Playlist in Web UI
Postby MrBadAxe » Tue Dec 20, 2016 6:06 pm
Problem Description:
* from Playlist tab, click "Create New Playlist". Nothing happens.
* Mouse over "Create New Playlist link", target is "javascript:noop()".
Playback Application and version:
default HTML5 web interface
Subsonic Version:
6.0 (build a7857c) – April 30, 2016
Server Version:
jetty-6.1.x, java 1.7.0_76, FreeBSD (53.0 MB / 119.0 MB) (FreeNAS-9.10-STABLE-201605021851)
Hardware Platform:
* ASRock AM1-H mini-itx motherboard
* AMD 5350 (quad core 2.05GHz)
* 8GB DDR3-1333
* 16GB SanDisk Ultra Fit USB drive (boot)
* 4 x 3TB WD Green HDD (storage, ZFS RAIDZ1)
Java Memory Limit: 150MB
MrBadAxe
Re: Can't Create Playlist in Web UI
Postby toolman » Tue Dec 20, 2016 7:48 pm
Did you use the openJDK-version or the Oracleversion of Java?
toolman
Postby acroyear » Tue Dec 20, 2016 8:15 pm
showing "noop()" isn't necessarily an indicator that something won't work - UI code generally does that ("return false;") to make sure that what callbacks are assigned in pure javascript don't also cause the page to open some other window.
I'm not saying there isn't some bug you're stumbling into, but just that the noop() alone isn't indicative of a problem but rather is a typical mechanism that web devs use in javascript.
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Postby MrBadAxe » Sat Dec 31, 2016 8:57 pm
toolman wrote:Did you use the openJDK-version or the Oracleversion of Java?
No idea; this is the FreeNAS Subsonic plugin and I assume the plugin architecture handles the Java install. Where do I look for this?
MrBadAxe
Postby toolman » Sun Jan 01, 2017 12:38 pm
I wouldn't know. You're the one who is running Freebsd. I'm running Subsonic on Windows server without any problems.
toolman
Postby billraff » Sun Jan 01, 2017 9:11 pm
I believe the 'About Subsonic' page should show the versions of pretty much everything.
billraff
Postby MrBadAxe » Wed Jan 04, 2017 5:53 pm
billraff wrote:I believe the 'About Subsonic' page should show the versions of pretty much everything.
Well, the original post is ^C^V'd straight from that page:
Does the fact that it says 'java' and not 'openjdk' imply that it's the Oracle version?
MrBadAxe
