Change Default Upload Location?
Postby tmwsiy » Wed Jan 04, 2017 2:24 am
is there a way to do that?
tmwsiy
Re: Change Default Upload Location?
Postby alphawave7 » Wed Jan 04, 2017 3:07 am
You mean run it from a different location?
viewtopic.php?f=6&t=9024
Postby tmwsiy » Wed Jan 04, 2017 3:18 am
Sorry, I was not very clear.
I'm talking about the default location where others can upload to my server.
I can click MORE and is currently set to Z:\Incoming.
I have no recollection on how I initially set that but would now like to change it to a new folder.
I see no way to do that.
Thank you.
tmwsiy
Postby toolman » Wed Jan 04, 2017 12:09 pm
Hi, That location is defined by Subsonic based on the location of your mediafolders.
It just uses the first folder you have defined under settings >> Mediafolder and adds an "Incoming" folder to that folder.
You can't change it without delving deep into the code. You can change it every time you upload a file.
But that means that you have to point to the file to be uploaded, change the destination folder, upload the file, get the "Succes"-message, return to the previous page, just to see that the folder has been changed to what Subsonic wants it to be.
So, this might be a feature request if you use this option a lot.
toolman
Postby tmwsiy » Thu Jan 05, 2017 2:31 am
toolman wrote:Hi, That location is defined by Subsonic based on the location of your mediafolders.
that is very helpful! thank you for explaining that.
tmwsiy
Postby Exrace » Sun Jan 08, 2017 5:20 pm
Keep in mind that path is what your server setup has access to.
If you're using remote UNC paths to a nas etc...you are better off using the UNC path to avoid having issues with drives that are not mapped or setup on the Subsonic server.
Exrace
