Videos freeze at 30 seconds
Postby GGC » Tue Jan 10, 2017 4:18 am
Hi all
All my videos stop playing at 30 seconds (or less).
It seems to be quit consistent over all video streams.
Here is the line from the log:
[1/10/17 4:15:18 AM GMT]   INFO   TranscodeInputStream   Starting transcoder: /var/subsonic/transcode/ffmpeg -ss 80 -t 10 -i /media/amnsr/A1_1T1/FILMS/1951/L'asso nella manica (Ace in the hole, 1951) Kirk Douglas - BD - Ita eng .mkv -s 960x698 -v 0 -b:v 3000k -maxrate 3000k -bufsize 256k -flags -global_header -map 0:0 -map 0:1 -ac 2 -f mpegts -c:v libx264 -preset superfast -c:a aac -b:a 96k -strict -2 -threads 0 -copyts -
[update] This seems to happen with Chrome and Opera, but curiously not with Firefox.
Best
Gabriel
License Subsonic Premium (expires May 29, 2017)
Version 6.0 (build a7857c) – April 30, 2016
Server jetty-6.1.x, java 1.8.0_111, Linux (73.9 MB / 133.5 MB)
GGC
Re: Videos freeze at 30 seconds
Postby GGC » Tue Jan 10, 2017 8:11 pm
To be precise, they seem to freeze exactly at 20 seconds.
GGC
Postby toolman » Wed Jan 11, 2017 1:21 pm
Your update is very interesting:
This leads me to think that it's not a Subsonic-issue but more a Chrome and Opera Issue.
If Subsonic streams your video fine to Firefox, it means that it is also streaming fine to Chrome and Opera, but something in these browser cause the session to lock up after 20 seconds.
Ever tried to clear the browser cache and temporary files for these browsers?
I can remember that a friend of me had a similar issue with music when he logged on to my Subsonic-server.
He always complained the music was stuttering and skipping. He used Chrome on a Windows machine.
I adviced him to use Internet Explorer and the issue was resolved. Chrome isn't that good apparently.
toolman
Postby acroyear » Wed Jan 11, 2017 2:58 pm
Perhaps look at the console logs? Sometimes I see "NETWORK_CONNECTION_RESET" type of errors when playback suddenly stops.
Also, if using the "*.subsonic.org" address, try switching to the direct connection's address instead. I've had issues with the redirects for large files before.
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Postby GGC » Thu Jan 12, 2017 9:11 pm
Cleaning Chrome's cash did not work.
GGC
Postby GGC » Thu Jan 12, 2017 9:12 pm
"Also, if using the "*.subsonic.org" address, try switching to the direct connection's address instead. I've had issues with the redirects for large files before."
I cannot ask this to my users.
GGC
Postby toolman » Thu Jan 12, 2017 9:52 pm
if you google on "Chrome problems streaming video" you'll find that in the past the problem was caused by a buggy flashversion or a Chrome plug-in that messed things up.
Perhaps you might try to remove Chrome and all of it's plug-ins you've installed and reinstall a clean copy of Chrome to see if that fixes the problem.
Again; Since you found that Subsonic can stream flawless to Firefox, it must be something in Chrome which causes the problem.
toolman
Postby GGC » Fri Jan 13, 2017 4:22 pm
First of all, thanks all for your comments.
I did try to reset Chrome with no success.
To make an independent assessment, I tried with two other devices and two operating systems:
On Android:
- Chrome has no plug-ins. Behaviour is the same, ie not working.
- Firefox works
- Dolphin and Opera: same as Chrome: not working
On Win 7 PC:
- (Resetted) Chrome (with no plug-in enabled): not working
- Fresh install Chrome: not working
- Firefox works
[Update]
On Win 10 PC:
- Chrome: not working
- Opera: not working
- Edge: works
Therefore, I would not conclude that "Chrome does not work" (also other browsers do not work, even on different operating systems).
I would rather conclude that the interaction between FlowPlayer and Chrome (and some other browsers) has some problem.
"If" that is the case, then the fact that Firefox works should give an hint on how to fix such 'interaction'. Most likely, this is not to be solved in every Chrome browser, though, but on the side of the SubSonic server.
Just to be clear, this might be specific to my installation of SubSonic server, not a general issue.
Am I saying anything unreasonable?
GGC
Postby toolman » Sat Jan 14, 2017 7:04 am
Since you are the only one that reports having issues with streaming video in various browsers I'm afraid it indeed is something in your setup which is interfering.
I have searched this forum for similar problems but it doesn't seem to be much of a problem with other users.
If you logon to your Subsonic-server and play a video in Chrome does it freeze at 20 seconds?
If so there are some options I can think of:
- you might need to look at the transcoding configuration for video?
- is your server powerfull enough?
- Perhaps you need to allocate more memory to Subsonic?
- Maybe there is a problem with your network-connection?
- Did you try to install Subsonic on the Windows 10 machine and stream video from that server?
- What's your uploadspeed?
If you don't have any issues playing video directly on your subsonic-server than there could be some problems with your network settings.
I guess Edge and Firefox are just a bit better in buffering streaming media and that's why your video's don't freeze in these browsers.
toolman
Postby GGC » Sat Jan 14, 2017 1:35 pm
Yes
That would require higher technical knowledge that the one I have. Any configuration to suggest?
[update] I tried this:http://forum.subsonic.org/forum/viewtopic.php?f=2&t=16801 with no visible difference
Yes, it works with other browsers
Not sure what this means. How do I try that? (But I do not see why streaming from one browser or an other should require more ram to the server)
No. It works with other browsers
Yes. Exactly the same behaviour
15.6 Mbps
GGC
Postby toolman » Sun Jan 15, 2017 12:51 am
Since you tried everything without any succes I really wouldn't know how to help you any more.
Just one thing:
- You can allocate more memory to subsonic by clicking Subsonic's tray-icon on your server. On the tab Settings you can change how much memory Subsonic may reserve. I believe the default setting is 256 MB.
By increasing the memory you can test if Subsonic's is able to stream the transcoded video more fluently which might sove your problem.
If that doesn't help than I can only tell you to just advice your users to use Firefox.
toolman
