Sharing - Content not available
Postby SNmusic » Mon Jan 23, 2017 1:20 am
Greetings,
I'm having troubles accessing shared media links. The page loads but the player window says "Sorry, the content is not available. Streaming by Subsonic". I've installed Madsonic using a different port and sharing works without issue. Any ideas on what I can check to resolve this issue?
Subsonic 6.0
Madsonic 6.2 beta
Thank you.
SNmusic
Re: Sharing - Content not available
Postby danobegood » Fri Feb 03, 2017 2:50 am
I ran into this too. Under Settings you have to go to Users, then select the Guest user, then check 'User is allowed to play files' and also ensure the desired media folder is checked in the 'Allow access to these media folders' section.
danobegood
Postby SNmusic » Sat Jun 03, 2017 3:56 am
Thank you! Thank you! Thank you! This issue was driving me nuts.
SNmusic
