SUBSONIC_USER not working still runs as root!
Postby operat0r » Wed Feb 01, 2017 1:40 am
* if I change the SUBSONIC_ARGS memory it changes so I know the file is being pickedup
* the subsonic user has normal user and can read/write to the music folder
* I did not have issues with this before
* Version: 6.0-1~getdeb1
* Ubuntu 16.04.1 LTS
* it worked before and works fine as root
ps auxwww|grep -ia subsonic
root     19965  0.0  0.0   7328   716 pts/12   S+   20:26   0:00 tail -f /var/subsonic/subsonic_sh.log /var/subsonic/subsonic.log /var/subsonic/db/subsonic.log
root     20649  325  1.6 3622360 274844 pts/11 Sl   20:36   0:09 java -Xmx100m -Dsubsonic.home=/var/subsonic -Dsubsonic.host=0.0.0.0 -Dsubsonic.port=4040 -Dsubsonic.httpsPort=0 - subsonic.contextPath=/ -Dsubsonic.defaultMusicFolder=/var/music -Dsubsonic.defaultPodcastFolder=/var/music/Podcast -Dsubsonic.defaultPlaylistFolder=/var/playlists -Djava.awt.headless=true -verbose:gc -jar subsonic-booter-jar-with-dependencies.jar
root     20715  0.0  0.0  14224   948 pts/11   S+   20:36   0:00 grep --color=auto -ia subsonic
root@plex:/etc/default# cat /etc/default/subsonic
# (/etc/init.d/subsonic)
# For example, to specify that Subsonic should use port 80 (for http)
# and 443 (for https), and use a Java memory heap size of 120 MB, use
# the following:
# SUBSONIC_ARGS="--port=80 --https-port=443 --max-memory=120"
SUBSONIC_ARGS="--max-memory=100"
SUBSONIC_USER="subsonic"
operat0r
Users browsing this forum: No registered users and 80 guests
