Subsonic stoped playing | database corrupt?
Postby produnis » Sat Feb 11, 2017 4:51 pm
I there, my 2 year old subsonic installation stopped playing files recently.
It shows all files, all playlists and all other stuff.
If I try to play a file or if I click on the "Podcast"-Tab, I get errors like this:
Exception    org.springframework.dao.TransientDataAccessResourceException
Message    PreparedStatementCallback; SQL [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
Java version    Oracle Corporation 1.8.0_121
Operating system    Linux 4.2.5-1-ARCH
Server    jetty-6.1.x
Memory    Used 114 of 145 MB
Stack trace    org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
   at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:81)
   at net.sourceforge.subsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:182)
   at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:120)
   at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:82)
   at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:149)
   at net.sourceforge.subsonic.service.PodcastService.addMediaFileIdToEpisodes(PodcastService.java:258)
   at net.sourceforge.subsonic.service.PodcastService.getEpisodes(PodcastService.java:208)
   at net.sourceforge.subsonic.controller.PodcastChannelsController.handleRequestInternal(PodcastChannelsController.java:63)
   at net.sourceforge.subsonic.filter.ResponseHeaderFilter.doFilter(ResponseHeaderFilter.java:47)
   at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:59)
   at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:227)
   at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:626)
Caused by: java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
   ... 67 more
My database file has 16GB (huge collection)
What I understand from the log file is, that these missing values ("?") might be the cause... Is my database corrupt?
produnis
Re: Subsonic stoped playing | database corrupt?
Postby toolman » Sat Feb 11, 2017 8:00 pm
It looks like your database indeed is corrupt.
You could try to fix it by
step 1. Delete all subscriptions to podcasts.
step 2. Disable all media folders.
step 4. Perform a folderscan.
step 5. When folderscan has finished do a database clean up.
stop 6. Enable all your media folders
step 7. Perform a folderscan.
step 8. When folderscan has finished do a database clean up again.
Your collection of 16 GB isn't really an issue, since Subsonic handles my collection of 1236.97 GB without any problem.
And there are Subsonic users with even bigger collections who don't have any database problem.
toolman
Postby G8DHE » Sat Feb 11, 2017 10:21 pm
Surely the database only holds pointers to the existing files, not the music data itself, hence the size of the files has no relevance ? Only the number of track records it holds.
Geoff G8DHE
Version 6.0 Beta 2
G8DHE
Postby produnis » Sun Feb 12, 2017 10:24 am
Hi and thx for your reply,
my Database, the file
/var/lib/subsonic/db/subsonic.data
has 16 GB
Anyway, I cannot remove Podcast subscriptions. If I click the tab "Podcasts", subsonic says
Error
I have no chance to remove any podcast.
scanning, and cleaning database do not seem to have any affect
All information about any song is displayed correct in the webinterface. How can this be if database is corrupt?
produnis
Postby toolman » Sun Feb 12, 2017 10:38 am
If your database is 16 GB than how large is your music collection?
If have a collection of 1 TB and my database is exactly 256 MB and has never been bigger nor smaller.
If you can't remove the podcasts, you could try skipping that step.
How big is your database file in the folder db.backup?
Perhaps you could stop the subsonic service and copy that file over to your db-folder.
You could also stop subsonic, delete your database file (or move it to another location ) and start subsonic again.
Subsonic will rebuild a new database, but you'll loose all your settings and you have to configure Subsonic from scratch. (Mediafolders etc.)
toolman
Postby produnis » Sun Feb 12, 2017 11:31 am
My mp3-folder has about 300GB, lots of audiobooks and documentations, subsonic.data has 16GB, subsonic.backup has 1.6 GB
I stopped subsonic, copied subsonic.backup to subsonic.data and restartet subsonic
the logfile says
INFO HsqlDaoHelper - Checking database schema.
[2017-02-12 12:25:09,063] ERROR HsqlDaoHelper - Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: error in script file line: 70 S1000 General error java.lang.NullPointerException in statement [SET TABLE MEDIA_FILE INDEX'2140627487 2142552709 2142552709 2142989656 2140609348 1076004777 82680864 1075928845 2138555723 2145831139 2137666176 2136785130 2136922339 98906']
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:382)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:429)
at net.sourceforge.subsonic.dao.schema.hsql.Schema25.execute(Schema25.java:39)
at net.sourceforge.subsonic.dao.HsqlDaoHelper.checkDatabase(HsqlDaoHelper.java:124)
at net.sourceforge.subsonic.dao.HsqlDaoHelper.<init>(HsqlDaoHelper.java:77)
at net.sourceforge.subsonic.dao.DaoHelperFactory.create(DaoHelperFactory.java:29)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:115)
at org.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:435)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateUsingFactoryMethod(AbstractAutowireCapableBeanFactory.java:903)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:817)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:135)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
Caused by: java.sql.SQLException: error in script file line: 70 S1000 General error java.lang.NullPointerException in statement [SET TABLE MEDIA_FILE INDEX'2140627487 2142552709 2142552709 2142989656 2140609348 1076004777 82680864 1075928845 2138555723 2145831139 2137666176 2136785130 2136922339 98906']
at java.sql.DriverManager.getConnection(DriverManager.java:664)
at java.sql.DriverManager.getConnection(DriverManager.java:208)
... 77 more
[2017-02-12 12:25:11,426] INFO SettingsService - Java: 1.8.0_121, OS: Linux
[2017-02-12 12:25:12,175] INFO VersionService - Resolved local Subsonic version to: 6.0
The Website gives the following error:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/index.view
Powered by jetty://
produnis
Postby produnis » Sun Feb 12, 2017 11:49 am
.... and my subsonic.data is again 16GB big.
Now I stopped subsonic, deleted subsonic.data und restartet subsonic,
and file subsonic.data ist created, and it immediatly increases up to 16GB again.
produnis
Postby produnis » Sun Feb 12, 2017 2:06 pm
I deleted everything in /var/lib/subsonic/db/
after that subsonic startet as a "fresh istall"
I added my stuff and successfully imported all files
my subsonic.data-file is now 250MB
The webinterfaces plays my music again, and my android-clients are able to log in and play music as well again...
It is a pitty that all my favourites, playlists and stars are gone...
produnis
Postby toolman » Sun Feb 12, 2017 2:28 pm
Yeah, It's a pity subsonic stores all that info in a database which gets corrupted so easily.
Let's hope Sindre abandons this buggy database and implements Mysql.
However the lesson here is backup, backup and backup.
Perhaps it might be an idea to add a backup feature to subsonic which can keep multiple backups.
toolman
Users browsing this forum: No registered users and 67 guests
