Java error after server migration
Postby nabab » Mon Feb 13, 2017 7:56 pm
I moved my subsonic installation from an Ubuntu 14.04 to 16.04, and since then I am getting the error pasted below when I try to reach it.
I use Apache as Proxy, with the exact same config I had on the older server.
Is this JSP error familiar to anyone by any chance?
23899 [btpool0-1] WARN org.mortbay.log - Nested in org.apache.jasper.JasperException: org.apache.jasper.JasperException: Unable to compile class for JSP
Generated servlet error:
The type java.lang.Object cannot be resolved. It is indirectly referenced from required .class files
at org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:84)
at org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:328)
at org.apache.jasper.compiler.JDTCompiler.generateClass(JDTCompiler.java:409)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:297)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:276)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:264)
at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:563)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:303)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:362)
at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:268)
at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:126)
at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:236)
at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:257)
at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1183)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:902)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:135)
at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:79)
nabab
Re: Java error after server migration
Postby nabab » Wed Feb 15, 2017 1:31 am
I stopped the service and removed the folder /var/subsonic and remade it through rsync with the previous' server's folder. It worked fine. The UNIX user is the same, the file /etc/default/subsonic also. Now when I launched a rescan of the library the server went mad again with the same error, and doesn't start since then.
Any idea?
nabab
Postby toolman » Wed Feb 15, 2017 10:50 am
I don't know anything about Ubuntu, but I've learned that a lot of Java problems arise when you are using Openjdk instead of Oracle Java.
Also it is of importance which version of Openjdk you are using.
It seems Subsonic does not seem to work with open JDK version 8 or 9 according to http://forum.subsonic.org/forum/viewtopic.php?f=2&t=17174&p=73296&hilit=java#p73296
toolman
Postby nabab » Tue Feb 21, 2017 11:11 pm
Thanks a lot I missed the answer, that was it!
nabab
