Trouble accessing music on a Synology DS1815+
Postby spdorsey » Sun Feb 19, 2017 7:41 pm
I have a Synology DS1815+ RAID on my network. I would like my Subsonic (Windows 10 Home) to access that library so that I can stream my music to my car when I drive. I am trying to set it all up, and I am running into all sorts of issues.
I found this info on how to access the library on the server:
http://sageadviceltd.com/running-subson ... -on-a-nas/
I have a username and password set up on the Synology to access the Music library read/write.
I tried to set up the same user on my Windows 10 PC, per the link, so that the Windows machine could access the Synology library with the proper credentials.
Windows 10 will not even let me create a user with the correct name. Very frustrating.
Is there a specific process I can follow to get this set up properly?
spdorsey
Re: Trouble accessing music on a Synology DS1815+
Postby toolman » Mon Feb 20, 2017 12:27 am
try this
Create a user Submusic with a password on your nas.
In Windows create a user Submusic with the same password
Next run "services.msc" and find the Subsonic service. Change the account under which it is running to the "Submusic" account. Stop and restart the service.
Log in to Subsonic and define your music folder like "\\NAS\MUSICFOLDER"
You'll notice immediatly if Subsonic has acces to that folder.
Of course the name of the user can be anything you like as long as you make sure it complies to the rules of both the OS of the Nas and Windows.
toolman
Postby spdorsey » Mon Feb 20, 2017 2:45 am
Well, I more or less did that. Then I pointed my Subsonic browser to the file path where my music folder is located (same file path I use in Windows to access it).
Subsonic started cataloging a TON of stuff (I have over 60,000 tracks). When it was done, the library was still empty. I have no idea why.
I have the Synology shared directory added to "My Computer" using the "Add Network Location" function.
I tried "Map Network Drive", but Windows hangs while scanning the network in the "Browse for Folder" window, the Synology never appears.
spdorsey
Postby toolman » Mon Feb 20, 2017 7:24 am
Did you give yourself privileges in Subsonic under Settings >> Users >> Allow access to these media folders ?
Can you map the drive by using the command prompt "Net use X \\nas\musicfolder" ? This will assign the driveletter X to musicfolder on the nas.
Also did you log in on Windows under the account you created for Subsonic to test if that account indeed has acces to the folder(s) on the nas?
What does Subsonic 's log file tell you?
What's the information on the "About Subsonic " page? Does it say something like :
2,511 artists
10,607 albums
147,946 songs
1236.87 GB
11,826 hours
toolman
Postby Marquepr » Wed Feb 22, 2017 8:28 pm
I am having the same issue. Subsonic is running on a Synology Nas where my music files are also stored.
The indexing proces went well. What is really weird is that I was able to browse and access files during the initial indexing process. But when the first indexing process completed, I lost acc to the library.
In the "Home" screen I can see the details of my media collection. In the Genres droplist, I can see a relevant genre list with an accurate count of my artists, but cannot load anything.
The Subsonic user on the Synology has read/write access to the music folder.
Subsonic log does not say much:
[2/22/17 8:47:13 PM CET] INFO HsqlDaoHelper Checking database schema.
[2/22/17 8:49:23 PM CET] INFO HsqlDaoHelper Done checking database schema.
[2/22/17 8:49:26 PM CET] INFO SettingsService Java: 1.8.0_121, OS: Linux
[2/22/17 8:49:28 PM CET] INFO VersionService Resolved local Subsonic version to: 6.0
[2/22/17 8:49:41 PM CET] INFO PlayerDao Deleted 1 player(s) that haven't been used after Sat Dec 24 20:49:41 CET 2016
[2/22/17 8:49:46 PM CET] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Thu Feb 23 03:00:00 CET 2017
[2/22/17 8:49:50 PM CET] INFO UPnPService Starting UPnP service...
[2/22/17 8:49:53 PM CET] INFO PodcastService Automatic Podcast update scheduled to run every 24 hour(s), starting at Wed Feb 22 20:54:53 CET 2017
[2/22/17 8:50:03 PM CET] WARN NetworkService No UPnP router found.
[2/22/17 8:50:13 PM CET] INFO SonosService No Sonos controller found
[2/22/17 8:50:14 PM CET] INFO UPnPService Enabling UPnP/DLNA media server
[2/22/17 8:50:14 PM CET] INFO UPnPService Starting UPnP service - Done!
[2/22/17 8:54:53 PM CET] INFO PodcastService Starting scheduled Podcast refresh.
[2/22/17 8:54:53 PM CET] INFO PodcastService Completed scheduled Podcast refresh.
[2/22/17 8:56:01 PM CET] INFO BootstrapVerificationFilter Servlet container: jetty-6.1.x
[2/22/17 8:56:14 PM CET] INFO VersionService Resolved latest Subsonic final version to: 6.0
[2/22/17 8:56:14 PM CET] INFO VersionService Resolved latest Subsonic beta version to: 6.0.beta2
[2/22/17 8:56:15 PM CET] INFO PlayerDao Created player 1.
[2/22/17 9:09:53 PM CET] INFO PlayerDao Created player 2.
Marquepr
Postby toolman » Wed Feb 22, 2017 11:10 pm
Dis you make syre that you're allowed to use the folders in Subsonic?
Settings >> Users >> Allow access to these media folders.
toolman
Postby Marquepr » Fri Feb 24, 2017 10:48 am
Thanks for your answer Toolman.
My issue is now solved. I cannot confirm the status of the user access to the media folder at the time of my initial post.
Before reading your answer, I upgraded the Synology to DSM 6.1, uninstalled and reinstalled Subsonic (using https://github.com/ghenry22/Subsonic_Sy ... tag/v6.0.0). I guess a bad permission was fixed somewhere in the process.
Marquepr
Users browsing this forum: No registered users and 76 guests
