Notice: LAME does not seem to be installed.
Postby tOaDeR » Fri Apr 10, 2009 5:44 pm
i am using Ubuntu Hardy Heron. i have LAME installed. its in /usr/bin. why can't subsonic find it there?
the music plays fine, but most of my mp3s have a high bitrate and i only have DSL, so i need to be able to downsample.
thanks in advance for your help.
tOaDeR
Postby jigsaw » Fri Apr 10, 2009 7:01 pm
It's a security feature:
The top one on 3.6 here: http://subsonic.sourceforge.net/changelog.php
# Security: For improved security, only transcoders installed in SUBSONIC_HOME/transcode are allowed to be executed. This includes LAME downsampling.
jigsaw
Postby tOaDeR » Fri Apr 10, 2009 7:09 pm
ok, so how do i downsample in linux if i don't know how to install it in a different directory?
is there a way to point subsonic to the version i have?
tOaDeR
Postby Clifff » Sat Apr 11, 2009 8:10 am
Assuming you installed Subsonic to /var/subsonic this command should do the trick.
sudo cp /usr/bin/lame /var/subsonic/transcode/
Clifff
Postby tOaDeR » Tue Apr 14, 2009 2:10 am
thank you so much. sorry it took so long, but i was away from home and couldn't apply that. it works great now
tOaDeR
Postby jarim » Thu Apr 16, 2009 6:55 am
Clifff wrote:Assuming you installed Subsonic to /var/subsonic this command should do the trick.
I would prefer:
ln -s /usr/bin/lame /var/subsonic/transcode/lame
jarim
Users browsing this forum: No registered users and 67 guests
