Unable to use HTTPS with Webplayer? Subsonic 6.0
Postby bigman » Tue Feb 28, 2017 4:22 pm
I'm running subsonic 6.0 on a raspberry pi. I have set up apache2 to serve up HTTPS through what I understand is an SSL reverse proxy. From outside my home network, I'm able to access the https site, log in, browse, and interact with the server. However, when I attempt to play through the webplayer, I get no sound output. The playlist loads, but nothing further happens.
If I access the "https" address through an iOS client, for example, everything appears to work fine.
If I drop the "s" and log in through simple "http", then the subsonic (and the webplayer) performs fine.
Is this a known bug that will be fixed in 6.1? Or, is this a configuration issue on my end?
Cheers
--bigman
bigman
Re: Unable to use HTTPS with Webplayer? Subsonic 6.0
Postby bigman » Wed Mar 01, 2017 12:46 pm
Nevermind. Today, it works. I have no explanation.
bigman
