Subsonic Not playing anything - current log
Postby coacharnold » Tue Mar 07, 2017 2:38 am
HELP,
MY subsonic server is not unable to play anything. I can see everything but not play. I've seen a lot related to this but no solutions ... I'm using Ubuntu 16:10 Here is my current log:
2017-03-06 21:33:55,457] ERROR RESTFilter - Failed to write error response.
java.lang.IllegalStateException: STREAM
at org.mortbay.jetty.Response.getWriter(Response.java:583)
at net.sourceforge.subsonic.controller.JAXBWriter.writeResponse(JAXBWriter.java:140)
at net.sourceforge.subsonic.controller.JAXBWriter.writeErrorResponse(JAXBWriter.java:154)
at net.sourceforge.subsonic.filter.RESTFilter.handleException(RESTFilter.java:76)
at net.sourceforge.subsonic.filter.RESTFilter.doFilter(RESTFilter.java:62)
at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:59)
coacharnold
Re: Subsonic Not playing anything - current log
Postby toolman » Tue Mar 07, 2017 12:00 pm
Perhaps you might take a look at the java version. Seems there's some issues with that. See http://forum.subsonic.org/forum/viewtopic.php?f=2&t=17174&p=73296&hilit=java#p73296
toolman
Postby coacharnold » Wed Mar 08, 2017 1:45 am
I am incredible frustrated .... I got nothing ... cannot play anything Loges still the same ... re-installed subsonic and Java 7 on ubunutu 16:10
Can anyone please help ... i'm banging my head against a wall
T
coacharnold
Postby toolman » Wed Mar 08, 2017 2:12 am
"Failed to write error response"
Could it be that you haven't set the proper permissions on the Subsonic folder?
Needs to be READ AND WRITE on the subsnic folder. Only READ on your media folders.
toolman
Postby toolman » Wed Mar 08, 2017 9:39 am
Is your server connected to your LAN by wires or wireless?
toolman
Postby coacharnold » Wed Mar 08, 2017 1:12 pm
Wired server.
Nothing has changed on my server, certainly not permissions.
I've litteraly been using this install for several years with no issue..
The only new this is that Ive been trying to get XENOamp to work, remotely. I can't see how this could affect subsonic, but it's the only thing ive been doing thats new.
Thoughts??
Tim
coacharnold
Postby toolman » Wed Mar 08, 2017 4:37 pm
Can you play music using subsonic webUI on the server itself?
Can you play music using the webUI on another computer?
When you re-installed Subsonic did you make sure to uninstall the old version?
Did you check after the uninstall if there were any remaining subsonic folders?
When I had problems with Subsonic I uninstalled it, deleted all folders that Subsonic left behind and than started a new installation. Doing so prevents that the new installation will pick up a faulty database from the previous version.
I've been running version 6 for almost a year now without any problems.
toolman
