Not playing all tracks in queue
Postby ezhawk » Thu Mar 09, 2017 5:41 pm
I have playlists set up that I listen to daily. I add the playlist to my queue and use shuffle and randomizing to not have the same sequence. I have noticed that the queue will not play all the songs. It will loop the same x number of songs. Seems to be between 20-50 songs that will will just run a loop of those songs in the queue.
I have ~350 tracks in the playlist and it used to roll through all 350 before going to the top and starting over. I've had much larger playlists in the past that worked fine.
Anyone else see this or have suggestions?
Subsonic Version: 6.0 (build a7857c) – April 30, 2016
System OS: Ubuntu 16.04.2 LTS
Server info: jetty-6.1.x, java 1.8.0_121, Linux (64.2 MB / 126.0 MB)
ezhawk
Re: Not playing all tracks in queue
Postby toolman » Thu Mar 09, 2017 6:02 pm
Is this issue with just 1 playlist or with several?
Did you try to export the playlist to check for any errors in the list itself?
In Windows you can open and edit playlists with Notepad.
toolman
Postby ezhawk » Fri Mar 10, 2017 1:57 pm
You know, I haven't seen if it happens on other playlists. I'll have to see if another playlist has the same behavior. I didn't try exporting the playlist to check for errors either. I'll do that too and see if I can see anything.
ezhawk
Postby ezhawk » Wed Apr 05, 2017 5:04 pm
So looked at the playlist after exporting it, didn't see any issues. I ended up rebuilding the list by hand from scratch and it seems like it's better and I haven't noticed it repeating the same songs. Must be something with the playlist itself.
ezhawk
Users browsing this forum: No registered users and 38 guests
